It is currently Sun Aug 24, 2025 4:08 pm
PostPosted: Thu Jun 16, 2011 7:29 pm
Good evening folks!
I know there are a couple of threads on powdercoating at the moment, but nothing overly specific about my questions, and I didn't want to bring up grandma from her thread grave.
I will be removing both my front and rear subframes from my Moke in the coming weeks and they'll be pulled down completely to be checked over and rebuilt.
I am looking at finishes for the stripped frames.
I know that powdercoat is very popular, but some people don't like it as it has a tendency to chip and then expose the often bare steel underneath.
POR range of finishes are also suggested... but these require brushing on?
Do they offer a pressure pack variety?
I hate the look of brush strokes in anything - one of the reasons house walls are often sprayed instead of the ancient method of brushing!
I am open to any input.
Cheers all.
Tyson.
PostPosted: Thu Jun 16, 2011 8:04 pm
You can spray it, but as far as I know it does not come in a pressure pack. It is self leveling and brushes on very well (it is extremely runny and quite thin, but sets hard). It would be good on a subframe, the only thing that really affects it is UV light.
PostPosted: Thu Jun 16, 2011 8:06 pm
P.S. You need to use the whole system (Marine Clean & Metal Ready) and make sure it is totally dry (use a heat gun) as any moisture and it will bubble and not stick! :)
PostPosted: Thu Jun 16, 2011 8:15 pm
As owen1975richard said, the POR is self levelling, and you won't get any brush strokes. But do make sure the surface is clean and level. Because it's self-levelling, any small bumps (around welds or where rust once was) tend to stick out and don't get painted.
PostPosted: Thu Jun 16, 2011 8:17 pm
I suggest you get them sandblasted and apply a 2 pack epoxy primer and top coat.
It's tough, shiny (if you want it to be), not effected by UV light & wont peel off.
PostPosted: Thu Jun 16, 2011 8:21 pm
Mods rock!
I've not long done some of mine in POR15. Just brush it on, by the time it dries, you'll be able to use it as a mirror, it's just amazing! Apply exactly as per instructions and wear gloves, it won't wash off! Best done on fresh abrasive blasted steel.
You won't be disappointed.
PostPosted: Thu Jun 16, 2011 8:27 pm
Excellent input guys.
GT mowog - you wouldn't happen to have any pics by chance would you?
PostPosted: Thu Jun 16, 2011 8:28 pm
[quote="GT mowog"] Apply exactly as per instructions and wear glovesquote]
Thanks GT for mentioning the gloves! Not only does it stop the paint from becoming a tatoo for the next three weeks, but more importantly, the Marine Clean will give you terrible burns in both neat and dilluted form. You must wear gloves and safety glasses when using it, as it will continue to burn your skin even after you have washed it off! Alkaline burns are extemely painful!
PostPosted: Thu Jun 16, 2011 8:34 pm
Totaly agree with Richard. I have POR15 my front subframe and Kill Rusted both Primer and topcoat Kill Rust the Rear. Althought both haven't been critical looked at since its been on the road I was more than happy with my brushed on coats of the POR15 (buy the Kit)
Por15 front
I also POR Clear Coat my engine
Sub Frames get them Straight and Strong and paint them and forget them I went POR15 as I didn't want to think about it again and the UV side of it, well when is going to see the sun and you can do it at home just follow the instructions. Give them a call they are very helpfull and ask questions. Amazing enough warmth is your friend
http://smg.photobucket.com/albums/v82/G ... 1QQtppZZ20
PostPosted: Thu Jun 16, 2011 8:36 pm
And don't wipe your face when you're painting with POR15.
I looked in the mirror when I was finished........awww crap!
For the next 3 months all I heard was "whats that mark on your head?" :lol:
PostPosted: Thu Jun 16, 2011 8:38 pm
Agree with the above. Don't worry about brush marks with POR 15. Follow the instructions exactly and it works great. Expensive but worth it
PostPosted: Thu Jun 16, 2011 8:43 pm
:lol: Yep fogot that Harley wear gloves at least and old long sleeved old cloths. once its on it takes some time to get off your skin.
you want to see your finger prints use wet & dry i did :wink:
PostPosted: Thu Jun 16, 2011 8:45 pm
Mods rock!
Not on this PC. I'll post some tomorrow.
<EDIT> I did find this one, possibly not the best pic but you'll get the idea
Brush painted, just with a $2.00 throw away brush!
PostPosted: Sun Jun 19, 2011 5:13 pm
Thanks for the pic!
That POR stuff looks great.
PostPosted: Sun Jun 19, 2011 8:22 pm
If you look in members mini gallery under slacko`s S , you will see my sub frames done in por 15 . I sprayed mine and then went over them with por 15 chassis black
Cheers Mark
