air conditioner wiring
https://www.ausmini.com/forums/viewtopic.php?f=2&t=71339
Author:  wolfmini [ Sat Jun 18, 2011 11:41 am ]
Post subject:  air conditioner wiring
Hi does anyone have a wiring diagram for rover air conditioning system?
i can't get the wire to switch on the compressor, i think the fault maybe a faulty switch or the way its wired up. (i did remove it and are putting it back in)
Author:  Morris 1100 [ Sat Jun 18, 2011 11:44 am ]
There is usually a low pressure switch in the system that will not allow the compressor to work if the gas level is too low.
See if you can find that switch and bridge it and see if the compressor kicks in.
Author:  wolfmini [ Sat Jun 18, 2011 11:48 am ]
thats prob it, i wanted to make sure it worked before regasing the system.
thanks for that morris 1100.
but if anyone does have a wiring diagram it would be useful for future reference.
Author:  wolfmini [ Sat Jun 18, 2011 12:00 pm ]
just checked the input to the relay switch, out of the 4 connections only 1 has 12volts, so im guessing the problem must be before that.
from what i figure,
- the switch has constant 12 v
- it switches 12 v to the switching wire which goes to the relay
- then from the relay it goes to the pressure switch
- then it goes to the compressor
is this correct?
Author:  EST-071 [ Sat Jun 18, 2011 1:17 pm ]
Have a look at the following link, it is for the later type of air-con (in dash type)
Cheers Pete
http://mini.nicehelp.co.uk/Circuit%20Diagrams.pdf
Author:  wolfmini [ Sat Jun 18, 2011 1:23 pm ]
awesome!! thats what i needed
cheers EST-071
