COOPER S DISTRIBUTOR, how to identify. https://www.ausmini.com/forums/viewtopic.php?f=2&t=7136 |
Author: | clubmn [ Fri May 13, 2005 8:06 am ] |
Post subject: | COOPER S DISTRIBUTOR, how to identify. |
I bought a massisave JOB LOT today, I am searching throught the parts i have and i have so far found cooper S spedo's, brakes, boosters, S boxes, airfilters etc, so much stuff. Anyway i am trying to distunguish a cooper S distrubtor apart from a standard. I havent been in the mini game for a while, so some help would be good. I know the major differance is no vacume advance, But pictures and stuff would help. |
Author: | drmini in aust [ Fri May 13, 2005 8:10 am ] |
They are a 23D4, no vac advance, & have a long pin for the breaker points. p/nos 40819B, or 40819H. |
Author: | min13k [ Fri May 13, 2005 8:43 am ] |
kev cooper s dissy were twin point to wernt they ?? makka |
Author: | drmini in aust [ Fri May 13, 2005 8:45 am ] |
min13k wrote: kev cooper s dissy were twin point to wernt they ??
makka NO. But they had 32oz points. ![]() |
Author: | min13k [ Fri May 13, 2005 8:45 am ] |
i'm sure i was told that ........ owell makka |
Author: | Mick [ Fri May 13, 2005 9:16 am ] |
Not near my MkII at the moment, so what are the part no.s for the MkII dizzys? I know they are quite different to all other mini dizzys in size(larger), but can't recall the number. |
Author: | drmini in aust [ Fri May 13, 2005 10:01 am ] |
Mick wrote: Not near my MkII at the moment,
so what are the part no.s for the MkII dizzys? I know they are quite different to all other mini dizzys in size(larger), but can't recall the number. My Clubby GT (with 1275S motor) had a 43D in it. ![]() |
Author: | 71_mini_k [ Fri May 13, 2005 10:25 am ] |
Here is a picture of a 23D it might help. ![]() I am running a 25D now and the main difference as far As I can tell is that the 23D does not have a vacuum advance but the 25D does. I used to have a 29D (special Aussie made version) ![]() |
Author: | clubmn [ Fri May 13, 2005 11:14 am ] |
Post subject: | 29D |
WHAT IS A 29D i have one of them as well? |
Author: | 71_mini_k [ Fri May 13, 2005 11:41 am ] |
The good Doctor could propably give you a full technical run down but as far as I know they are a "Made in Australian" version of the the 25D with the main difference being that the 25D has an external vacuum advance adjuster where the 29D does not. I have run both in my with my 1152 and they both preform about the same. |
Author: | drmini in aust [ Fri May 13, 2005 1:34 pm ] |
29D (with vac) was used on Mini K and early Clubbie. Then they changed to using 45D. As far as S dizzys go, IMO they are overrated, and most now are probably worn out. These days points are passe. I bet a stock Pulsar electronic dizzy with it's std advance curve would make an S perform better than its original. OK.. so it's not an item for concours cars.. ![]() |
