Temp sender adaptor
https://www.ausmini.com/forums/viewtopic.php?f=2&t=71472
Author:  Fiji [ Fri Jun 24, 2011 7:37 pm ]
Post subject:  Temp sender adaptor
Changing my mechanical temp gauge to electrical 1275 block.
I had a look around struggling to find an adaptor from block to suit my electric sender.
Part : SMITT6811-01 1/8"
I could probably cut a thread at work into the smaller adaptor bush in pic to fit the sender but is there a single bush that would do the trick from the block to sender?
Author:  drmini in aust [ Fri Jun 24, 2011 7:47 pm ]
If you post me the sender I will make you one.
The thread in the head is 5/8-18 UNF.
Author:  GT mowog [ Fri Jun 24, 2011 7:56 pm ]
The thread on his new sender is 1/8" 27 NPT.
Author:  drmini in aust [ Fri Jun 24, 2011 8:00 pm ]
I said before- (I have that tap, give me dimensions needed or a sketch and I will make and post).
[edit] I can make from a 3/8 or 1/2 BSP brass hex plug, dimensions not needed now.
Author:  EST-071 [ Fri Jun 24, 2011 8:02 pm ]
If you can I would like 2 of them as well.
Cheers Pete
Author:  drmini in aust [ Fri Jun 24, 2011 8:05 pm ]
I'll knock some up early next week.
Author:  Fiji [ Fri Jun 24, 2011 8:34 pm ]
Thanks Doc. Pm sent
Solid work GT
Cheers. Sean
Author:  drmini in aust [ Mon Jun 27, 2011 9:15 pm ]
Guys I've got the 3 hex brass plugs, will machine them on Thursday (aka Mini machine shop day). :P
Author:  CPOCSM [ Tue Jun 28, 2011 7:34 pm ]
I will take one also Doc if there are any left... :D
Author:  drmini in aust [ Tue Jun 28, 2011 7:53 pm ]
No problem.
Author:  Wombat [ Wed Jun 29, 2011 10:05 am ]
Is 5/8-18 UNF standard bolt size/thread? - need a blanking bit for my extra thermostat hole
Author:  GT mowog [ Wed Jun 29, 2011 10:24 am ]
Yes. It is just 'ordinary' 5/8" UNF. the '-18' bit is the threads per inch. If your fitting a steel bolt, grease it to slow the rusting / corrosion.
Author:  drmini in aust [ Fri Jul 01, 2011 5:00 pm ]
OK guys these 4 are in the mail, if anybody else wants one made too, $12 ea including post.
Author:  DTrain [ Mon Jul 04, 2011 10:21 pm ]
will send you a pm when i get home doc, im in need of an adapter of slightly different nature
