Interior light door switches - available?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=71660
Author:  rup [ Sun Jul 03, 2011 9:38 pm ]
Post subject:  Interior light door switches - available?
Are these available anywhere? Or fixable, they look simple but I can't see how they are supposed to push, where is the spring!
This is from a '70 mini K. I'd like to keep the original style if possible.
Author:  Lockie91 [ Sun Jul 03, 2011 9:55 pm ]
im pretty sure I have that same style. They are in my for sale section thread.
Author:  rup [ Sun Jul 03, 2011 10:08 pm ]
Ta. I will have a look.
Author:  TheMiniMan [ Sun Jul 03, 2011 10:54 pm ]
i`m sure i have a pile of new old stock ones, i`ll double check tomorow
Author:  arjay [ Sun Jul 03, 2011 11:57 pm ]
You could always get these as an alternative:
http://jaycar.com.au/productView.asp?ID ... rm=KEYWORD
Author:  rup [ Mon Jul 04, 2011 7:20 am ]
Lockie: Thanks mate. I think yours might be the ones with a lobe with a hole in it. Can you check. Mine are completely round and press fit with no extra bit visible when in place.
Mini Man: Thanks heaps, it would be great if you could check. If they look like mine then I'd love to get a couple.
arjay: Cool - I've spent hours in that shop and never seen those! Thanks. I'll get mini ones if I can, pref these suckers with the round mounting.
Author:  woodwormm [ Mon Jul 04, 2011 12:10 pm ]
mini's got the round push in ones... but they pull out stupidly easy..
is this just cos they're old are they meant to press in tightly?
Author:  rup [ Mon Jul 04, 2011 1:57 pm ]
Yeah. They are fairly rubbish. Mine were not too loose. If they were I reckon I'd be able to splay out the fitting a little. Problem with mine is the push-in bit doesn't spring out properly so they never switch anything on.
Author:  TheMiniMan [ Mon Jul 04, 2011 5:08 pm ]
yes i do have a few of them, they`re all new-old-stock genuine items, also have door buffers & SU fuel pump contact sets etc etc etc,,, there`s even a new flasher-switch cancellation lever with new rivet :-)
anyways, i`ll work out a price for them & reply to all the PMs about the switches
& anyone interested in the other stuff in the pic i`ll sort prices for them too
Matt
Author:  drmini in aust [ Mon Jul 04, 2011 5:32 pm ]
The Rover ones are a better switch (cheap too), the originals were never great as they are steel and corrode, and there is no real positive connection to the body.
All you have to do to fit Rovers is drill one hole (and the screw earths the switch properly). Best thing I ever did, the switches work all the time!! :P
Author:  adamstuart [ Mon Jul 04, 2011 5:45 pm ]
How much for the black and white thongs?
They look the goods!
Author:  jester99 [ Mon Jul 04, 2011 6:41 pm ]
I have these fitted to my mini. I have installed an alarm system and wanted to upgrade to a better switch. I have also fitted one of these to the bonnet. so far they have been good.
Author:  Morris 1100 [ Mon Jul 04, 2011 7:10 pm ]
We have these switches in trucks at work, they don't like dirt or dust or moisture. They are junk.
The trucks at work have a warning system in place to prevent the driver leaving the truck without applying the parking brake. (the horn blows if the door is opened with the handbrake off!) These rubbish switches keep failing to work.
Author:  marks [ Mon Jul 04, 2011 9:02 pm ]
Try John at the mini king.
I've got a pair of new ones last year. My springs had gone and full of dust & paint from an old respray.
I think less that $10 each and have been fault-less on the daily driver.
Cheers.
Author:  rup [ Tue Jul 19, 2011 7:28 pm ]
Got a new pair from TheMiniMan (thank's Matt). Here's a new one and an old roger'd one. A perfect match.
And installed. Interior lights working - well dim glowing anyhow - sweet.
Thanks for the help everyone.
