With ignition on, power goes from 12v to the voltage stabiliser at the back of the speedo, then from the other side of the stabiliser to the Temp guage. (Also to the Fuel Gauge). The other wire from the temp gauge goes to the sender, which earths through the engine block to give a reading.
If you use lots of teflon tape on the sender it will prevent it working.
Dioes the fuel guage work and is it relatively accurate? If so, the voltage stabiliser (small squarish tin can behind the speedo) is working.
I'd check the wiring between the voltage stabiliser and the guage, then the wiring from the gauge to the sender.
It's highly unlikely to be the gauge itself.
_________________ Brett Nicholson Greendale (near Ballan) VIC. 1971 Morris Mini Moke 1966 Austin Mini 1965 Morris Mini Traveller 1973 LR Series 3 88 2007 LR Freelander 2
