tools
https://www.ausmini.com/forums/viewtopic.php?f=2&t=71723
Author:  mini_mel [ Thu Jul 07, 2011 5:34 pm ]
Post subject:  tools
i was wondering if someone can tell me what tools i will need in order to rebuild a mini motor
i was going to get someone to reface the heads and refurbish the block and i was going to put it back together but i still need to pull it apart so i guess i have to fork out for whatever tools you need
Author:  GT mowog [ Thu Jul 07, 2011 5:53 pm ]
Have a look in here
http://www.ausmini.com/forums/viewtopic.php?t=67980
Phat Kat wrote:
Tools
As well as you’re normal tools (screw drivers, files, taps, pliers etc.) there are a few special tools and pieces of measuring equipment you will need. These include:
Micrometers: ( 0 -1” .... 1-2”....2-3” but at the very least a set of 1-2” micrometers. This is an imperial motor, so buy imperial Micrometers).
Feeler Gauges
Dial Gauge (and stand)
Plastigauge (strongly recomended)
A ground straight edge (decent steel rule might get you by)
Torque Wrench (1/2 drive that will cover a range from 25ft/Ibs to 150ft/Ibs)
Imperial Socket set
Piston Ring Compressor
Valve Spring compressor (or a work shop press)
And if you can afford it, get an engine stand... they make life so much easier
OH and don’t forget the most useful tool of all... a workshop manual appropriate for your motor.
Author:  thomas_hb [ Thu Jul 07, 2011 5:53 pm ]
An imperial socket set.
A flywheel puller.
An engine crane.
Author:  Wombat [ Thu Jul 07, 2011 5:54 pm ]
How big is your budget?
Author:  greyghost [ Thu Jul 07, 2011 7:21 pm ]
ive rebuilt motors with nothing more than a torque wrench, a socket set and a good set of feeler guages
the big thing to remember is you can never be too clean, your workshop should resemble a doctors surgery
Author:  mickmini [ Thu Jul 07, 2011 9:06 pm ]
but with less sick people.
I find a good workbench is essential. Plus an engine stand can come in handy if you want to go that way - bearing in mind that most have to be modified to mount an A-series block on them.
Author:  AEG163job [ Thu Jul 07, 2011 10:48 pm ]
Leave it until it get's warmer.
Then again maybe its not too bad with all this global warming , otherwise we would all be really freezing our arses off!
minus 6 here again tomorrow :x
Author:  thomas_hb [ Fri Jul 08, 2011 3:35 pm ]
While we're at it, Adamstuart didn't reply to a text message I sent in April so now I'm going to name and shame him.
Author:  adamstuart [ Fri Jul 08, 2011 4:41 pm ]
You sent me a text in april?
news to me!
