oil change - how do you do it ? https://www.ausmini.com/forums/viewtopic.php?f=2&t=71745 |
Page 1 of 2 |
Author: | _666_ [ Sat Jul 09, 2011 2:44 pm ] |
Post subject: | oil change - how do you do it ? |
its come time to change the oil in my car.. however i always seem to have the issue of not being able to fit a standard oil catch tray under the mini.. i was just curious as to how people have overcome this ? Nick, |
Author: | i got a mini [ Sat Jul 09, 2011 2:58 pm ] |
jack the car up ![]() |
Author: | Morris 1100 [ Sat Jul 09, 2011 3:03 pm ] |
Roll the car up onto a couple of blocks of wood. (two short bits of plank) You can also use the blocks of wood to lift the car so that the floor jack will slide under easier. |
Author: | _666_ [ Sat Jul 09, 2011 3:10 pm ] |
i got a mini wrote: jack the car up
![]() then wouldnt the oil pool at the back of the gearbox and not drain out propperly ? |
Author: | Maxi23 [ Sat Jul 09, 2011 3:17 pm ] |
I just cut a section out of my plastic oil tray / tub, enough to slide it in under the corner of the sump plug. |
Author: | Tombo [ Sat Jul 09, 2011 4:11 pm ] |
I like to reverse my mini onto ramps then jack the front on a bit of an angle so the drain plug is the low point in the sump. |
Author: | woodwormm [ Sat Jul 09, 2011 7:54 pm ] |
i've got a couple of garden sleepers with angles at one end... poke each angle under the front wheels and drive up onto the timbers, puts the car 4 inches higher off the ground and still flat, heaps easier than jacking imo.... the reason i've got them is that i needed them to get the jack under my last rx7... found em when moving house and realised they were long enough for both front and back wheels on a mini ![]() |
Author: | drmini in aust [ Sat Jul 09, 2011 8:15 pm ] |
My driveway faces downhill. I run the LF wheel up on a housebrick, this puts the drain plug at the lowest point and gives height for the drain tray. ![]() |
Author: | Convertible Mini [ Sun Jul 10, 2011 7:58 am ] |
Post subject: | Oil Change |
Always make sure the engine is at running temperature before you drain the oil. It flows out quicker when hot. And you will also know when it is running down your arm! |
Author: | Irish Yobbo [ Sun Jul 10, 2011 1:14 pm ] |
I just use ice-cream containers - I use two small 2l containers which fit under the sump. I wait for one to fill, swap it with the smaller one and pour into a bigger ice-cream container. When the next one fills I swap them again. Yeah, probably more complicated than it needs to be, but cheap and cheerful. |
Author: | Morris 1100 [ Sun Jul 10, 2011 1:20 pm ] |
My oil drain pan is one of these... ![]() It is great, you still need to be careful when pouring the oil oil back into a bottle but it is better than any other one I have used. It does need a section for the sump plug to sit and maybe even a spot to sit the filter to let it drain. I might just make a grate from a fridge shelf to drain the filter into the pan. |
Author: | BBY755 [ Mon Jul 11, 2011 11:10 am ] |
Yeah, It's a bugger to find a low enough one. That looks the goods! |
Author: | Lillee [ Mon Jul 11, 2011 12:03 pm ] |
Step 1) Buy an ultra low trolley jack... |
Author: | goodie [ Mon Jul 11, 2011 12:16 pm ] |
All good ideas , another that you could try is to run 1 side up onto the gutter to give you the height. Just be careful of spillage . |
Author: | bnicho [ Mon Jul 11, 2011 1:26 pm ] |
drmini in aust wrote: My driveway faces downhill. I run the LF wheel up on a housebrick, this puts the drain plug at the lowest point and gives height for the drain tray.
![]() That's what I do too. The driveway I use is also gravel, so if I spill a little oil, it just helps keeps the weeds from growing through. ![]() |
