It is currently Wed Jul 23, 2025 8:43 am
 Post subject: Bearing cap question
PostPosted: Thu Jul 14, 2011 6:24 pm
High heel ninja
I have just found 2 main bearing caps, both have N275 stamped into them,
Could I assume they are for a 1275?
Doogie
PostPosted: Thu Jul 14, 2011 7:58 pm
Measure across their bore, if over 2-1/8" yeah they probably are.
PostPosted: Thu Jul 14, 2011 10:27 pm
the number stamped on them "Usually" ties in with the 3rd main cap &&& the block that they came off will (or should) have the same number stamped into it near/rear of the water-pump area
