It is currently Fri Jul 25, 2025 9:00 am
 Post subject: Gearbox Leak
PostPosted: Sun May 15, 2005 12:05 am
Gday all. Well need some advice in getting one of those stop leak kits for a rod change gearbox on. I have the kit however how many seals are there in the actual holewhere the rod thingy comes out of the box. I ask as I removed the outer seal(or the remnants of it anyway...)but went to put the alloy, o-ringed bush in and only pushed on JUST inside the recess. Does this thing have to go in further, do I remove the inner seal as well and then insert it??
Your advice needed
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sun May 15, 2005 6:48 am
There is normally only one seal fitted, but many cars out there have 2 in there (as there's room to bung another in if it leaks). You will need to dig out that inner one too.
Is the kit better than just 2 new seals? I dunno.. :lol:
