It is currently Fri Jul 18, 2025 9:04 pm
PostPosted: Mon Jul 18, 2011 7:43 pm
Can anyone help...
With either photos or somewhere to take measurements, having to clear alot of bits and what to see if i have an auto frame in a car i have before i get rid of it.
I know its wider but where and by how much etc..
Thanks
PostPosted: Mon Jul 18, 2011 7:57 pm
Here's an auto subframe.
On a manual subframe, the edge highlighted yellow is straight, and the edge highlighted red is close to straight too.
PostPosted: Mon Jul 18, 2011 7:59 pm
Easiest way to tell- the bit of steel that goes across the front of an auto subby is curved forward an inch or so. This is to make room for the autobox front cover's removal. (auto box is mounted about 20mm further forward)
Manual ones are straight here, not curved.
Engine mount holes are different too.
PostPosted: Mon Jul 18, 2011 8:46 pm
Also The Auto frame is wider at/between the engine mounting area(s)
PostPosted: Tue Jul 19, 2011 11:44 am
The sides of the subframe where the engine bolt to on either side have been cut and curve away from the engine its approx 68cm across. The bottom seam running front to back is cut away also....
Hope this helps
61 van
63 countryman
63 saloon
67 auto
73 auto clubman
75 1000cc clubman
77 sccr 998 clubman
NZ 79 1275gt clubman estate
79 LE
80 meanee
Racecar
Fiat 500
 Post subject: Auto subframe
PostPosted: Tue Jul 19, 2011 3:23 pm
from memory i think i just made a 9-10mm spacer on one side of the engine mounts and the manual engine slotted in place.
PostPosted: Tue Jul 19, 2011 3:40 pm
Does this help?
Mini Matic front subframes have the box section across the front you can see below the front valance on my Moke. It's commonly unbolted and removed, but the ear-like mounting points, with two holes in each, on either side of the subframe will still be there.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Jul 19, 2011 4:40 pm
Hmmm - is the subframe on the 1100 also different between the manual and the auto ?????
Morris 1100 I am talking about not the engine size. Too lazy and too cold to go outside and look.
Mike
PostPosted: Tue Jul 19, 2011 4:59 pm
Mike
Yes. The front rail and the clutch/torque converter side are different.
The Auto frame also has a pair of mounts for a bash guard (which I am missing)
PostPosted: Tue Jul 19, 2011 5:15 pm
The bash guard is what I was referring to in my post above as the "box section" across the front.
I reckon PVA would have a Morris 1100 Auto one. I have a Mini one, but it fouled on the Park switch, so I took it off the Moke.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Jul 19, 2011 5:26 pm
Damn - I was hoping to just drop the engine in the other shell - dropping the fluid and the sub-frames was something I did want to do.
Mike
