Differences between and auto and munaul front Subframe?! https://www.ausmini.com/forums/viewtopic.php?f=2&t=71921 |
Author: | Blunder [ Mon Jul 18, 2011 7:43 pm ] |
Post subject: | Differences between and auto and munaul front Subframe?! |
Can anyone help... With either photos or somewhere to take measurements, having to clear alot of bits and what to see if i have an auto frame in a car i have before i get rid of it. I know its wider but where and by how much etc.. Thanks |
Author: | drmini in aust [ Mon Jul 18, 2011 7:59 pm ] |
Easiest way to tell- the bit of steel that goes across the front of an auto subby is curved forward an inch or so. This is to make room for the autobox front cover's removal. (auto box is mounted about 20mm further forward) Manual ones are straight here, not curved. Engine mount holes are different too. |
Author: | TheMiniMan [ Mon Jul 18, 2011 8:46 pm ] |
Also The Auto frame is wider at/between the engine mounting area(s) |
Author: | dougys [ Tue Jul 19, 2011 3:23 pm ] |
Post subject: | Auto subframe |
from memory i think i just made a 9-10mm spacer on one side of the engine mounts and the manual engine slotted in place. |
Author: | bnicho [ Tue Jul 19, 2011 3:40 pm ] |
Does this help? ![]() ![]() Mini Matic front subframes have the box section across the front you can see below the front valance on my Moke. It's commonly unbolted and removed, but the ear-like mounting points, with two holes in each, on either side of the subframe will still be there. Cheers, |
Author: | Mike_Byron [ Tue Jul 19, 2011 4:40 pm ] |
Hmmm - is the subframe on the 1100 also different between the manual and the auto ????? Morris 1100 I am talking about not the engine size. Too lazy and too cold to go outside and look. Mike |
Author: | Morris 1100 [ Tue Jul 19, 2011 4:59 pm ] |
Mike_Byron wrote: Hmmm - is the subframe on the 1100 also different between the manual and the auto ?????
Morris 1100 I am talking about not the engine size. Too lazy and too cold to go outside and look. Mike Yes. The front rail and the clutch/torque converter side are different. The Auto frame also has a pair of mounts for a bash guard (which I am missing) |
Author: | bnicho [ Tue Jul 19, 2011 5:15 pm ] |
Morris 1100 wrote: Yes. The front rail and the clutch/torque converter side are different.
The Auto frame also has a pair of mounts for a bash guard (which I am missing) The bash guard is what I was referring to in my post above as the "box section" across the front. I reckon PVA would have a Morris 1100 Auto one. I have a Mini one, but it fouled on the Park switch, so I took it off the Moke. |
Author: | Mike_Byron [ Tue Jul 19, 2011 5:26 pm ] |
Damn - I was hoping to just drop the engine in the other shell - dropping the fluid and the sub-frames was something I did want to do. Mike |
