Oil on plugs?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=71931
Author:  Booglie [ Tue Jul 19, 2011 3:02 pm ]
Post subject:  Oil on plugs?
What could be causing plugs two and three of my mini engine to be getting covered in oil, while plugs one and four are perfect?
Author:  sgc [ Tue Jul 19, 2011 3:20 pm ]
Valve guides? I have a similar problem, I'm going to yank the head this week hopefully and have a look..
Author:  GT mowog [ Tue Jul 19, 2011 6:14 pm ]
Bad leads, dissy cap or bad plugs.
Author:  drmini in aust [ Tue Jul 19, 2011 7:42 pm ]
I agree with GT m, a bad coil H/T lead was gafmo's problem recently.
Put a meter on each lead end to end, and move the lead around. If it reads over 4000 (4K) ohms I bin them, ditto if the reading changes when moved about.
Gafmo's was reading from about 8000 ohm to infinite in places. :shock:
Cheap supression leads are just carbon impregnated `string' inside, after a few years installed they have had it.
I have had good results with Bosch inductive core leads from Supercrap, $5.95 each lead. Had them in for years and they still read about 1.8K ohm as new.
Author:  gafmo [ Tue Jul 19, 2011 8:04 pm ]
Yep just to add to GT & Dr I had replaced the lead to the spark plugs but not the HT lead to the Coil. I replaced the lead with a New 1 and not long after it started again. So I also have a new Coil to install on the weekend
it does sound like you had the same problem I had/have but I would also inspect your dizzy cap and rotor if not replace
What dizzy are you using as I have a Pulsar
Author:  Monaco [ Tue Jul 19, 2011 8:40 pm ]
:oops:
Author:  Booglie [ Tue Jul 19, 2011 9:48 pm ]
I have a megajolt setup using the old leads with the clips on the coil side, I have a few newer leads lying around so i'll try a few different ones and see how it goes.
Author:  simon k [ Tue Jul 19, 2011 10:45 pm ]
Booglie wrote:
I have a megajolt
you shoulda mentioned that in the first post....
Try testing/swapping the leads around, but if you still find that #2 & #3 are oily, it means that "half" of the coil pack is cactus. THe coil pack is 2 coils with 2 terminals each, one of the coils fires #1 & #4, the other is #2 & #3
If it is, don't go and get another Ford coil, get one from a Hyundai Excel. Check my howto on instructions on hooking it up
