Were any Australian models fitted with lights in the rear pockets? Reason I ask is I pulled out the card lining for the rear pockets and removed the blue fur (
) the PO had stuck on and got to what looks like the original surface - off white painted card and in the vertical part under the ash tray hole was another rectagular hole and a small round hole under it looks like a light fitting hole but no wiring anywhere to be seen.
David L
