It is currently Wed Jul 23, 2025 7:47 pm
PostPosted: Thu Jul 21, 2011 3:55 pm
Does anyone know the size and thread of the bolts that secure the lower rebound rubbers to the front sub-frame?
Ive painted and prepared my subframe but when I went to put the new rubbers back in Ive noticed there's no holes so I must have sheared the bolts and forgot then painted over it :oops:
I assume it uses 2 bolts and not just one and a locating pin?
PostPosted: Thu Jul 21, 2011 4:01 pm
1 only each side, pretty sure they are just self tappers..
[goes to check Mini King cattledog...]
yep GHF425- screw, self tapping, multi use, SD1/SE
Last edited by drmini in aust on Thu Jul 21, 2011 4:03 pm, edited 1 time in total.
PostPosted: Thu Jul 21, 2011 4:03 pm
I think they were self tappers too, but mine were stripped and nothing held in there, so what I did was tap it #10 UNF (or M5 equivilent) and put a Button head screw in there.
Far more secure.
PostPosted: Thu Jul 21, 2011 5:50 pm
They are 10-32 (or sometimes referred to as 3/16" UNF).
PostPosted: Thu Jul 21, 2011 6:23 pm
While where on the topic: the castor rods, do they have one or two cup washers for the rubbers, each side.
PostPosted: Thu Jul 21, 2011 6:33 pm
Only one, between the outer rubber and nut.
PostPosted: Thu Jul 21, 2011 6:37 pm
The subframe should have a cup washer fixed to both sides
So it goes tie bar -> bush -> subframe cup washer -> other side subframe cup washer -> bush -> outer washer -> nut -> then sometimes an R clip (if the tie bar has a hole drilled)
PostPosted: Thu Jul 21, 2011 6:38 pm
There's a Cupped Washer and Flat Washer (which is similar OD to the Cupped Washer). Remember, most of the braking force is tranmitted through these to hold the rest of the car back! The forces on them can be huge.
PostPosted: Thu Jul 21, 2011 7:07 pm
The late cars just had the cupped washer, but it is about 3 or 4mm thick, is that more than the early ones?
PostPosted: Thu Jul 21, 2011 7:39 pm
I've not measured the thickness of them, but they are heavy, probably around the 3 mm mark.
<EDIT> Here's some I prepared earlier
PostPosted: Thu Jul 21, 2011 9:06 pm
Thanks, Think Ive got it now.
PostPosted: Fri Jul 22, 2011 10:01 pm
Where did you get that diagram from, I have the BMC red manual but there's nothing like that in it.
PostPosted: Sat Jul 23, 2011 5:18 am
:lol: , BMC / Leyland Parts Book. Workshop manual only assumes all the parts are there to start with and that you'll put them all back in!
Even then, that diagram only shows (for example) one rubber, however when you read the list, is says two.........
PostPosted: Sat Jul 23, 2011 7:38 am
If you can't get an original parts manual get hold of Mini Kings Catalogue - it has all the sections with numbered exploded diagrams.
PostPosted: Thu Jul 28, 2011 12:03 pm
I was wondering where the other rubber was.
Anyway Im at work but have some time to grab the bolts while on lunch, But I dont have the sizes with me.
Does anyone know the sizes of
The upper bump stop bolts, Two screw type.
The castor rod bolts
The lower control arm bolts
I assume these are all ny-lock?
Any help would be appreciated, It will save me a trip across town.
Users browsing this forum: Bing [Bot] and 105 guests
