Arrgh!! engine removal question?-DRIVESHAFTS!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=7202
Author:  dansedgli [ Sun May 15, 2005 1:48 pm ]
Post subject:  Arrgh!! engine removal question?-DRIVESHAFTS!
Hi guys,
today Im attempting to take out the old engine and gearbox so I can start on the body work of the car.
I think Ive got everything covered except getting the driveshafts out of the gearbox/diff.
This is the first FWD car Ive done an engine on so Im at a loss and the engine crane needs to go back tonight. :cry:
How do they come out? A simplified explanation would be great!
Thanks a lot!
Author:  9YaTaH [ Sun May 15, 2005 2:00 pm ]
Post subject:  Re: Arrgh!! engine removal question?-DRIVESHAFTS!
dansedgli wrote:
Hi guys,
Thanks a lot!
Depends on the type of joint...pot or cross unijointed thingy....search for driveshaft on ausmini....there are whole discussions...get yourself a manual ans follow the steps...be careful lifting as the the shafts can foul the engine as it is going up....
Author:  doogie [ Sun May 15, 2005 2:01 pm ]
What type are they? if the are pot joint type you undo & release a ball joint ad they pop out, if the are rubber uni type you undo all the u bolts & removed the uni joint, if they are steel cooper s type you undo the 4 nyloc nuts & pry the uni off with a screw driver only if needed, usually a light tap gets the off.
Doogie
Author:  dansedgli [ Sun May 15, 2005 3:02 pm ]
Thanks guys, I have managed to get one off so far.
Im draining the oil now, I got a bit covered.
I have no idea what type they are, they arent uni's from what I can tell so far. There is the driveshaft from the wheels, then a big cylindrical section, then the section after that enters the diff. This just pulled out after a bit of convincing.
Once the oil has drained Ill tackle the other one and it should be ready to lift out.
I cant wait to get it all painted and put a daihatsu engine in its place!
Author:  gafmo [ Sun May 15, 2005 3:10 pm ]
You will find they are Pot Joints and should have just poped out once you released the top ball joint :wink:
Author:  dansedgli [ Sun May 15, 2005 3:12 pm ]
I didnt release any to ball joint :) Which one is that? oops.
Im new to this front wheel drive stuff and trying to wing it without the manual, My printer is on something ATM and only prints out half of a line of text at a time.
Author:  gafmo [ Sun May 15, 2005 3:15 pm ]
Top and and some time the bottom may help....and pull the top out and the shaft should pull out of the pot joint.
Getting the pot joint is another joy unless the have a special tool but you may be lucky with two screw drivers on each side :?
Author:  Mini Mad [ Sun May 15, 2005 3:29 pm ]
I find you can get the shaft out of the pot joints on the way out without popping the ball joint...getting them back in is another story :evil:
Author:  gafmo [ Sun May 15, 2005 3:37 pm ]
Putting back in...Bottom Ball joint on and rool it towards the engine with the othe hand place the sharft on the edge and spin the shaft till she pops in...Then place the top ball jpint in..You may need a Jack to lift the top arm and an extra pair of hands :wink:
Author:  dansedgli [ Sun May 15, 2005 3:59 pm ]
Thanks guys, I managed to get the other out without undoing the top joint, engine is out now!
The project can begin. wOOt! :D
Author:  gafmo [ Sun May 15, 2005 4:06 pm ]
Excellent..Go on take some picks of what you have done :wink:
Author:  dansedgli [ Sun May 15, 2005 4:23 pm ]
Will do, expect some photos in the gallery shortly.
Author:  drmini in aust [ Sun May 15, 2005 4:48 pm ]
If you've removed the pots from the side covers and find it hard getting them back in :x , change the wire circlips on the diff output shafts.. :lol:
Author:  dansedgli [ Sun May 15, 2005 5:19 pm ]
Pic thread here:
http://forums.ausmini.com/viewtopic.php?t=7209
