how does this work?? https://www.ausmini.com/forums/viewtopic.php?f=2&t=72050 |
Page 1 of 2 |
Author: | Lockie91 [ Sun Jul 24, 2011 10:36 am ] |
Post subject: | how does this work?? |
http://www.ebay.com.au/itm/SANDBLASTER- ... 27bbdf8c29 thinking with the amount that I'm going to pay a sand blaster to do my work, I might get away with this, for future use.. How are you supposed to use this without loosing all the beads to not use again and making a mess? I was thinking of going for a cabinet one, like this http://www.ebay.com.au/itm/SANDBLASTING ... 45fab3d1c3 but then they are slightly to small to fit the subframes in, which is the biggest thing I'd want to blast... ![]() Any ideas anyone? |
Author: | 123grosso [ Sun Jul 24, 2011 11:02 am ] |
You could use the first one, and build a box so you dont lose all the stuff, just an idea |
Author: | Lockie91 [ Sun Jul 24, 2011 11:08 am ] |
123grosso wrote: You could use the first one, and build a box so you dont lose all the stuff, just an idea
Author: | 123grosso [ Sun Jul 24, 2011 11:21 am ] |
Good point, i didnt think of that, then build a booth ![]() |
Author: | The Duckmeister [ Sun Jul 24, 2011 11:25 am ] |
^^ That's what I was thinking too. |
Author: | 123grosso [ Sun Jul 24, 2011 11:27 am ] |
Great minds think alike My mate called google gave me this link, i just looked at the pictures cause it was too long for my attention span http://www.ford-trucks.com/article/idx/ ... binet.html |
Author: | GT mowog [ Sun Jul 24, 2011 11:41 am ] |
You do loose all your blasting media and it does make a mess. You need a cabinet or booth to contain the mess and a broom to re-claim it ![]() |
Author: | Lockie91 [ Sun Jul 24, 2011 11:54 am ] |
123grosso wrote: Good point, i didnt think of that, then build a booth
![]() ehhhh NOOO.. sorry but this is defeating my purpose of getting it, to save money in the long run.. i wouldn't bother otherwise.. Anyone out there actually used one of these before please? |
Author: | adamstuart [ Sun Jul 24, 2011 12:08 pm ] |
I've used one similar, hooked up to a heffen big compressor It was lacklustre, and only if you stood there long enough... It also had a reclaim system on it (fancy term for a vacuum that sucks near the outlet) Relclaim system did sweet fiddle sticks all, still had to sweep up huge amounts of media |
Author: | blueminivan [ Sun Jul 24, 2011 12:32 pm ] |
The cabinet blasters are the bomb. Great for small items. If you have a large compressor, and I mean a good high volume compressor, they work well and save hours from wirer wheeling and sanding. If blasting anything big, don't stuff around, just it to a blasting shop. ![]() |
Author: | Gadgets mini [ Sun Jul 24, 2011 12:43 pm ] |
make a cabinet out of plywood and line it with Gal sheeting |
Author: | adamstuart [ Sun Jul 24, 2011 1:09 pm ] |
blueminivan wrote: The cabinet blasters are the bomb. Great for small items. If you have a large compressor, and I mean a good high volume compressor, they work well and save hours from wirer wheeling and sanding.
If blasting anything big, don't stuff around, just it to a blasting shop. ![]() +1 I've used a cabinet compressor hooked up the same heffin big compressor as the portable blaster thing lockie linked Cabinet was far superior Wouldn't dream of doing anything bigger than a door though.. (that took a painfully long time) |
Author: | DTrain [ Sun Jul 24, 2011 2:27 pm ] |
get a trap, put the subframe on it, lift the corners |
Author: | Mick [ Sun Jul 24, 2011 5:32 pm ] |
You could line the place in the black plastic they use in construction. Like the home painters do. The garnet won't have enough energy to punch through, like the rubber gloves in blasting cabinets. You can lift the plastic up to gather the garnet together for sieving (with the wife's finest colander) and reloading into the canister. |
Author: | Morris 1100 [ Sun Jul 24, 2011 5:47 pm ] |
The main thing is to make it so you are not breathing the stuff you blast off. A dust mask will last about 3 seconds. |
