It is currently Wed Aug 13, 2025 3:52 am
 Post subject: Distributor Question
PostPosted: Mon Jul 25, 2011 12:08 am
Just wondering if anyone can tell from looking at this picture which lead hole is for which cylinder ? Ive just painted my engine and dont particularly fancy having to take the little timing cover off :lol: i guess if it has to be done ill do it.
Thanks,
Bill
PostPosted: Mon Jul 25, 2011 6:31 am
You can't guarantee the correct order by looking at it, but you could start at 2 o'clock (the default position) and move it around one place through trial and error, but that depends on you having marked the dizzy location before removing it. h=The lead order is 1-3-4-2 in an anti clockwise direction.
Before you remove the timing cover from the painted engine, get a stanley knife and run it around the head at the junction between the head and the rocker cover gasket. That will stop the paint from splitting off. Its hard not to ruin the two timing cover bolts however..
PostPosted: Mon Jul 25, 2011 8:15 am
ill give it a go mick cheers
PostPosted: Mon Jul 25, 2011 9:47 am
if you loosen & swing down the little timing mark cover plate (on the clutch cover),,, then turn (rotate) the engine till you see the TDC marks (5deg & 10deg etc),,, then take the oil filler cap off & feel inside to number one inlet valve rocker & fiddle it to see if it has clearance
well if it has clearance then you`re on the firing stroke & put the number one lead where the rotor is pointing at that spot
if it doesn`t have clearance then either -->fit the number one lead opposite to where the rotor is pointing
or--> rotate the engine one full turn & test again
got it?
Users browsing this forum: No registered users and 296 guests
