It is currently Sat Aug 02, 2025 1:46 am
PostPosted: Sun Jul 24, 2011 10:29 am
Anyone got some nice pics of twin tanks with Aston caps on? Just picked up a set for Barney's about to be refurbished bum (he's coming home on Tuesday) and need to know which way's up and which is down. Plus, I want to see just how 'phwooooooaaaaar' he will look!
Evan
PostPosted: Sun Jul 24, 2011 10:31 am
the flap swings down to open, so it hangs down when it`s open,,, that way you can fill the thing without having to hold the flap up
Latch at the top,,, i put it on a slight angle to suit the same line as the rear body seams actually,,, looks more ass-thletic :-)
PostPosted: Sun Jul 24, 2011 6:15 pm
Ah, I see. Cheers!
PostPosted: Sun Jul 24, 2011 7:46 pm
Ill agree with Matt. Catch on top when released it sits and just fill the tank and put the cap on and flip it back up. They do look great also :wink:
PostPosted: Sun Jul 24, 2011 8:37 pm
except for the fuel trail from them leaking...
And you can't use them on a racetrack.
PostPosted: Sun Jul 24, 2011 8:41 pm
Mine is firm as and have to push on it to lock the cap (not the cover)
PostPosted: Sun Jul 24, 2011 9:17 pm
Mine doesnt leak at all.
Mine is the type that flips up, and then you remove the cap with a key.
:D
PostPosted: Sun Jul 24, 2011 11:13 pm
:D
Yep same here. Harley you can spine it 180 degrees
PostPosted: Mon Jul 25, 2011 6:16 pm
Thought you might like some pics?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Jul 25, 2011 6:20 pm
British people do some monstrous things to their cars :shock:
You're so square
Baby I don't care
PostPosted: Mon Jul 25, 2011 6:34 pm
Isn't that what he asked for in the first place?
PostPosted: Wed Jul 27, 2011 10:30 am
To be "Race Track Legal" they require a hole drilled through the catch.
A length of twisted SS Lock Tie wire through the hole & across the cap under the hinge to stop the catch moving.
Actually ,under the hinge first ,then "figure 8" through a bigger hole in the catch.A couple of twist on the 2 ends is all is required. Stainless Lock Wire lasts forever.
All the old Historic Open Wheeelers do this.
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Wed Jul 27, 2011 12:46 pm
yep Dicko, you`re correct
sorry here you go, a couple of one of my cooper tank caps-->
not exactly the way i like them fitted but they`re stuck on there really ****** hard so that`s where they stayed :-) & don`t mind the rust please... i don`t :-)
