It is currently Thu Jul 24, 2025 5:13 pm
 Post subject: lowered mini's
PostPosted: Mon May 16, 2005 11:12 am
just wondering if anyone has lowered there mini? i was think bout doing it and i got 12x5 rims... how many inches lower should i go? or should it not be done in general?
PostPosted: Mon May 16, 2005 11:16 am
Personal preference.
I'm giong to raise mine, as I have 12x5's and they rub on the plastic flares, which never sounds good.
Are you trying to bottom the car out, or just take a bit out?
 Post subject: .
PostPosted: Mon May 16, 2005 11:18 am
just take a bit out.... my body seems to sit pretty high of the tyres thats all? but i dont want the exhast line hittin the floor or nuffin
PostPosted: Mon May 16, 2005 11:25 am
http://www.ausmini.com/forums/viewtopic.php?p=80963#80963
This link goes to photos of my car.
How low is this compared to your car?
PostPosted: Mon May 16, 2005 11:31 am
hi-lo's then you lower or raise to your hearts content. I think on the lowest of my hi-lo's i can just fit/squeeze a finger between the wheel and guard...
PostPosted: Mon May 16, 2005 10:22 pm
If you have good cones (clubman/non hydro suspension) then it will sit quite high. The normal 12 x 5s have the same outside diameter as the 10s so that doesnt make much difference. Mine was sitting too high, just put the HiLos in and you can set the ride height to whatever you want. I wanted mine lowered for better handling/corner speed, and it looks muchus betterus :)
78 van 1300 cam extractors weber, 12" Superlights Metros Konis HiLos MP3 Amp Sub Alpine speakers and lots of fur
www.crazybitchracing.com
PostPosted: Mon May 16, 2005 10:33 pm
I could get DEFECTED at any moment... the lowest part of mine is 65mm off the ground... speed bumps :evil:
dont worry im jacking it up on the w/e hopefully
PostPosted: Mon May 16, 2005 10:59 pm
Lowest point on mine is 44mm.
Thats the sump guard.
And, 30 year old cones at the front.
:shock: :D
PostPosted: Mon May 16, 2005 11:33 pm
:shock: :D
oh yeah I forgot to mention..
if you have 30yr old cones you dont need HiLos :P
PostPosted: Mon May 16, 2005 11:41 pm
Marcia's at her Lowest but Just able to get a Hydo Jack under
No she's not on the road
PostPosted: Mon May 16, 2005 11:47 pm
wookd moite ;) thats one pimpin Mini gafmo, dare ya to take it through licensing like that :)
PostPosted: Tue May 17, 2005 8:12 am
Mine's got new cones front and back so as you can imagine it sits a bit high, can't lower her too much though or the ruddy huge muffler would be ripped off going over the next speedhump, who invented those bloody things anyway, I know what I'd like to do to him :twisted:
PostPosted: Tue May 17, 2005 9:17 am
Have we found out whether we're talknig about a hydro or dry mini here?
PostPosted: Tue May 17, 2005 3:32 pm
huh :?
Does it matter?
PostPosted: Tue May 17, 2005 3:57 pm
Just re-read..doesn't really matter to the height it should be, but the method of acheiving the height would be different...I think he has a dry mini anyway :)
Users browsing this forum: Bing [Bot] and 81 guests
