snapped manifold stud https://www.ausmini.com/forums/viewtopic.php?f=2&t=72571 |
Author: | jordy.... [ Sun Aug 21, 2011 8:26 pm ] |
Post subject: | snapped manifold stud |
As per the subject, i have shaped a manifold stud in half been trying to. Losen it but its way too tight any suggestions?? |
Author: | Timbo [ Sun Aug 21, 2011 8:35 pm ] |
Is any of it sticking out, or did it break flush or below the surface? Tim |
Author: | goodie [ Sun Aug 21, 2011 8:40 pm ] |
How much stud is left coming out of the head ? You can get a tool for removing studs , and the Snap - On brand one that i have seen , worked really well . Someone on here may have a picture of one so you can see what they look like .Check out some reputable tool sellers to see what they have . |
Author: | i got a mini [ Sun Aug 21, 2011 8:40 pm ] |
umm yer have fun lol my brother broke one and he had to either take the head off or pull the engine out to fix his |
Author: | MORRIS COOPER S 501 [ Sun Aug 21, 2011 8:48 pm ] |
If there is any stud left, put two nuts on the stud, lock the nuts together and then try undo the stud. |
Author: | simon k [ Sun Aug 21, 2011 9:07 pm ] |
whatever you do... DON'T TRY TO USE AN "EASY-OUT" !!! if there isn't any stud poking out, remove the head before you try anything, its just too awkward otherwise - always ends in pain |
Author: | Mini_Maxx [ Sun Aug 21, 2011 9:39 pm ] |
If its busted off flush, drill a hole in it, belt in a suitable allen key and twist it out. Worked everytime for me |
Author: | mini_mad_matt [ Sun Aug 21, 2011 11:31 pm ] |
I've found torx bits work very well as "easy outs" ![]() The only times i've seen people using easy outs they have broken, making it even worse |
Author: | blue_deluxe [ Mon Aug 22, 2011 12:01 am ] |
Im yet to find an easy out that works, If that doesnt work then drill through and helicoil. If you dont have a pedestal drill then find someone who does and make sure its square. |
Author: | drmini in aust [ Mon Aug 22, 2011 8:23 am ] |
In my trade I was taught to do this properly.... Drill it on centre (and square) to the tapping size for that thread, then screw a tap in. Bingo the stud's remains come out easy. If the stud is broken off crooked I drill it out in the mill, using a slot drill not a twist drill. ![]() |
