It is currently Sun Aug 10, 2025 5:43 am
 Post subject: do you know
PostPosted: Tue Aug 23, 2011 6:51 pm
This mini? :
http://www.carsales.com.au/all-cars/pri ... &silo=1011
and opinions on price etc, interested in buying it, viewing it on sunday, so just want some ideas from you guys.
Shaan
PostPosted: Tue Aug 23, 2011 8:15 pm
Nup
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Tue Aug 23, 2011 8:20 pm
Haven't seen it on this forum
PostPosted: Tue Aug 23, 2011 8:32 pm
Looks like a bitza!
Front valance looks like pre 65.
Wiper motor is from after 68. (with the early wiper pattern!)
UK boot lid.
Clubbie tail lights
Lift up door handles.
Clubman interior and column.
Body is a roundie. (it is not a clubbie with a nose job.)
It would be interesting to see what the numbers on the ID plate say.
PostPosted: Tue Aug 23, 2011 9:10 pm
Certainly seems to be a cut n shut, though I guess somebody could have put in the time to change B pillars before it was painted.
EDIT: just read the description: yep cut n shut.
PostPosted: Tue Aug 23, 2011 9:14 pm
Looks like a bitza!
You sure it's not a clubby witha nose job? Sure looks like it to me, even the inside the lower dash is clubby, maybe early clubby circa 72-73 grafted to a 65 deluxe firewall/wings....
cheers,
PostPosted: Tue Aug 23, 2011 9:18 pm
Not many people would change the firewall when doing a nose job.
It's possible though.
PostPosted: Tue Aug 23, 2011 9:40 pm
probs just an 80's half half cut and shut
Vehicle ID SSE-AD-178411 ?
PostPosted: Tue Aug 23, 2011 9:53 pm
A '64 bonnet won't fit a clubby firewall unless you relocate the hinge mounting position. I was going to suggest that it was a flappy door handle Mini K with clubby taillights, but it has a full front valance.
There used to be a Mini with a UK bootlid getting around Hobart a long time ago. It could be the same car.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Aug 23, 2011 10:49 pm
originality aside, would it be a rather rust free, decent engine mini at a reasonable price?
oh and 'cut n shut'?
PostPosted: Tue Aug 23, 2011 11:00 pm
"Cut & Shut" - it's the front of one car (the claimed '65 model bit) grafted to the back of a much later body.
You'd want to hope the claim of "professionally done" is correct and have a damn close look at it. If you're not too sure yourself of what you're looking for, take someone who does know their stuff with you for their opinion as well.
If it all checks out OK and you're not too fussed about its lack of originality, it's probably worth having a decent think about.
After all, it's still a Mini. :)
PostPosted: Tue Aug 23, 2011 11:21 pm
Supposing the panels were individually removed and correctly welded back to the car, then it would be considered okay, but if it looks like there is a join in the floor and or roof then it's not been done properly, and would therefore be a 'Cut and shut', which is illegal as it messes with the vehicles structural integrity.
I know where there is a 1275LS with a weld running clean around the middle of the roof and floor. Once this was found out, the car was written off, and will never see the road again. :cry:
Users browsing this forum: Bing [Bot] and 117 guests
