What size is the top subframe bolt on a Rover?!?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=72600
Page 1 of 2
Author:  Blunder [ Mon Aug 22, 2011 11:15 pm ]
Post subject:  What size is the top subframe bolt on a Rover?!?
as it says... so far i have figured it's bigger than 32mm as thats the biggest socket in the tool box!!! lol
thanks
Author:  Asphalt [ Mon Aug 22, 2011 11:26 pm ]
1 5/16" :) (about 33.3mm)
Author:  Harley [ Tue Aug 23, 2011 8:42 am ]
Which is a good socket to have if you own a mini as it also fits disc brake hub nuts, steering wheel retainer nut, and varoius engine ones you'll probably never need.
Author:  drmini in aust [ Tue Aug 23, 2011 8:52 am ]
Check your hub nut size, before buying a 1-5/16" socket.
Recent ones are made from 34mm hex bar. If this includes yours I'd buy a 34mm socket instead. It will still fit your steering wheel, crank pulley bolt and camshaft nut. :wink:
Author:  poeee [ Tue Aug 23, 2011 9:40 am ]
Does 15/16 whitworth ring a bell?? (my old mans shed is mostly whitworth 8) )
Author:  Harley [ Tue Aug 23, 2011 10:09 am ]
Whitworth? You wash your mouth out........
:lol:
Author:  weevel [ Tue Aug 23, 2011 10:49 am ]
Bloody hard to find in the local shops when i looked, most places stopped at 1 inch in Imperial measures.
Author:  Harley [ Tue Aug 23, 2011 10:54 am ]
You can get the right sockets in real tool shops, or truck stores.
Author:  Blunder [ Tue Aug 23, 2011 12:47 pm ]
cheers guys think i will be buying a 34mm......
lol
Also on a bit of a side note, i'm doing this to get the steering rack out, how do you go at getting the crappy snap bolts off the column bracket!?
Author:  Beanie [ Tue Aug 23, 2011 12:55 pm ]
Vice grips .. i know it sounds a bit rough but it works ... Good Vice grips not cheap copys ...
Author:  bill.b [ Tue Aug 23, 2011 7:45 pm ]
:lol: don't forget to re-torque correctly with vice grips.
Author:  Blunder [ Tue Aug 23, 2011 10:39 pm ]
do you need to loosen off both top bolts..... To get the steering rack out?
On the Rover the passanger side bolt is a %@# to get at!!!!
Author:  Asphalt [ Tue Aug 23, 2011 11:36 pm ]
...or weld a nut on... And don't forgett to wrap a pillow round your head when you pull the steering wheel off!! :lol: (don't ask me how I know... *smack!* :twisted: )
Author:  1098 [ Wed Aug 24, 2011 12:14 am ]
Vice Grips? Christ thats rough.
Author:  drmini in aust [ Wed Aug 24, 2011 8:13 am ]
Beanie is talking about the conical `security nut' on the top column bolt, not the steering wheel nut.
I cut a flat on it first to give a grip.
I didn't bother fitting another funny nut, I used a real one. :wink:
