Main points to look at for a RWC https://www.ausmini.com/forums/viewtopic.php?f=2&t=72624 |
Author: | Kermit [ Wed Aug 24, 2011 1:05 pm ] |
Post subject: | Main points to look at for a RWC |
Hi once again im after some advice and anything you can help me with would be much appreciated ![]() I am about to take my mini for a road worthy check and im wondering what are the things they look for so i can fix them if need be befor it goes in? thanks again guys ![]() |
Author: | poeee [ Wed Aug 24, 2011 1:21 pm ] |
Brake flexible hoses - check for any cracking (probably just swap them) Wheel cylinders - roll the dust seal back and check for fluid Meat on brakepads/shoes, and undersized discs/oversized drums Ball joints - I always replace them, or you could lap them and re-shim depending on condition Shocks - any leaks usually Seat belts - any signs of fraying or fading Rips in seats Fuel flexy lines Bad oil leaks About all I can think of at the moment. |
Author: | Kermit [ Wed Aug 24, 2011 2:02 pm ] |
thanks for the reply. most of them im sure are fine but ive still gotta check out the brakes properly and go over the lines. cheers ![]() |
