It is currently Sun Jul 20, 2025 6:17 pm
 Post subject: BEST AIR FILTER
PostPosted: Fri Aug 26, 2011 8:36 pm
Hi All,
I've changed from a 6" inch long RAMTUBE and replaced with RAMFLO air filter, now is running like a pig. I took the ramtube off as I put the standard dash centre binnacle back in, but the ramtube now impedes the speedo cable, so changed to the ramflo on the single 1.5 SU, the manifold is 20mm longer so can't fit the big metal air intake. It appears that the ramflo element/sponge material is restricting airflow.
IS there, better air filter to use has any one else had a similiar problem? ALL suggestions welcome
PostPosted: Fri Aug 26, 2011 9:06 pm
Piper Cross ramtube socks I have found to be the best out of all that I have tried (Ramflo, K&N, Unifilter). Low to no restriction, easy to take off and pop on for cleaning
PostPosted: Fri Aug 26, 2011 9:11 pm
You can get right angle speedo adapters that will stop the cable fouling on the ramtube. I can't find a link to any at the moment but a lot of early british cars use them.
Cheers Pete
Edit: Found one but not cheap
PostPosted: Fri Aug 26, 2011 9:26 pm
Around $80 from minis.com.au last time I checked
PostPosted: Fri Aug 26, 2011 9:31 pm
Thanks Lillee, was just about to ask you where from. :D Yeah I'll have to cut/machine the ramtube down to fit both.
PostPosted: Fri Aug 26, 2011 9:43 pm
No need, get some of these:
http://www.dellorto.com/merchandise/pro ... ctionID=41
Or these:
I have the latter and are good. They sell longer ones, just get the ones that fit
PostPosted: Fri Aug 26, 2011 9:49 pm
Sorry Minis.com.au don't sell the right angle bracket anymore.
Pipercross can be had from
http://www.dellorto.com/merchandise/pro ... ctionID=64
PostPosted: Fri Aug 26, 2011 9:55 pm
minisplus do sell an airfilter sock though, weber foam reusable filter sock any good? $21
PostPosted: Fri Aug 26, 2011 9:57 pm
You can buy shorter ram tubes http://www.minispares.com/Product.aspx?ty=pb&pid=32805
PostPosted: Fri Aug 26, 2011 10:07 pm
Ramflo filters do have too much restriction, but just use Unifilter's polyurethane foam pads in them instead.
Unifilter's p/nos:
LNX300 for SU, LNX400 for Weber/Dellorto.
$9.20 each the last time I bought any.
[edit] My 1360 got 86.6HP ATW with one of these on, I have the trophy to prove it.
My 1412 stroker got 114HP at the crank, same setup- it made the same HP with and without the filter on it. So the Unifilter foam's restriction is minimal.
Last edited by drmini in aust on Fri Aug 26, 2011 10:23 pm, edited 1 time in total.
PostPosted: Fri Aug 26, 2011 10:09 pm
Milatsmadmini
Or these:
i got a pair of them on my weber with some nicely oiled filter socks, looks the goods, and sounds great! 8)
PostPosted: Fri Aug 26, 2011 10:10 pm
Where did you get them from Kev?
PostPosted: Fri Aug 26, 2011 10:14 pm
www.uniflow.com.au but they have agents everywhere, like Western Filters.
Link to product- http://www.uniflow.com.au/contents/en-us/d141.html
Last edited by drmini in aust on Fri Aug 26, 2011 10:16 pm, edited 1 time in total.
PostPosted: Fri Aug 26, 2011 10:16 pm
http://www.minis.com.au/minis/catalog/p ... cts_id=413
PostPosted: Fri Aug 26, 2011 11:44 pm
ive got a pipercross one on mine from minisport uk, as said above it just slips over the tubes and the difference with or without it is absolutely none
Users browsing this forum: Bing [Bot] and 84 guests
