BEST AIR FILTER https://www.ausmini.com/forums/viewtopic.php?f=2&t=72663 |
Page 1 of 2 |
Author: | MORRIS COOPER S 501 [ Fri Aug 26, 2011 8:36 pm ] |
Post subject: | BEST AIR FILTER |
Hi All, I've changed from a 6" inch long RAMTUBE and replaced with RAMFLO air filter, now is running like a pig. I took the ramtube off as I put the standard dash centre binnacle back in, but the ramtube now impedes the speedo cable, so changed to the ramflo on the single 1.5 SU, the manifold is 20mm longer so can't fit the big metal air intake. It appears that the ramflo element/sponge material is restricting airflow. IS there, better air filter to use has any one else had a similiar problem? ALL suggestions welcome |
Author: | Lillee [ Fri Aug 26, 2011 9:06 pm ] |
Piper Cross ramtube socks I have found to be the best out of all that I have tried (Ramflo, K&N, Unifilter). Low to no restriction, easy to take off and pop on for cleaning |
Author: | EST-071 [ Fri Aug 26, 2011 9:11 pm ] |
You can get right angle speedo adapters that will stop the cable fouling on the ramtube. I can't find a link to any at the moment but a lot of early british cars use them. Cheers Pete Edit: Found one but not cheap |
Author: | Lillee [ Fri Aug 26, 2011 9:26 pm ] |
Around $80 from minis.com.au last time I checked |
Author: | MORRIS COOPER S 501 [ Fri Aug 26, 2011 9:31 pm ] |
Thanks Lillee, was just about to ask you where from. ![]() |
Author: | Lillee [ Fri Aug 26, 2011 9:43 pm ] |
No need, get some of these: http://www.dellorto.com/merchandise/pro ... ctionID=41 Or these: http://www.dellorto.com/merchandise/pro ... ctionID=41 I have the latter and are good. They sell longer ones, just get the ones that fit |
Author: | Lillee [ Fri Aug 26, 2011 9:49 pm ] |
MORRIS COOPER S 501 wrote: Thanks Lillee, was just about to ask you where from.
![]() Sorry Minis.com.au don't sell the right angle bracket anymore. Pipercross can be had from http://www.dellorto.com/merchandise/pro ... ctionID=64 |
Author: | MORRIS COOPER S 501 [ Fri Aug 26, 2011 9:55 pm ] |
minisplus do sell an airfilter sock though, weber foam reusable filter sock any good? $21 |
Author: | BALLISTIC [ Fri Aug 26, 2011 9:57 pm ] |
You can buy shorter ram tubes http://www.minispares.com/Product.aspx?ty=pb&pid=32805 |
Author: | drmini in aust [ Fri Aug 26, 2011 10:07 pm ] |
Ramflo filters do have too much restriction, but just use Unifilter's polyurethane foam pads in them instead. Unifilter's p/nos: LNX300 for SU, LNX400 for Weber/Dellorto. $9.20 each the last time I bought any. [edit] My 1360 got 86.6HP ATW with one of these on, I have the trophy to prove it. My 1412 stroker got 114HP at the crank, same setup- it made the same HP with and without the filter on it. So the Unifilter foam's restriction is minimal. |
Author: | mattsmadmini [ Fri Aug 26, 2011 10:09 pm ] |
Lillee wrote: No need, get some of these:
http://www.dellorto.com/merchandise/pro ... ctionID=41 Or these: http://www.dellorto.com/merchandise/pro ... ctionID=41 I have the latter and are good. They sell longer ones, just get the ones that fit i got a pair of them on my weber with some nicely oiled filter socks, looks the goods, and sounds great! ![]() |
Author: | MORRIS COOPER S 501 [ Fri Aug 26, 2011 10:10 pm ] |
Where did you get them from Kev? |
Author: | drmini in aust [ Fri Aug 26, 2011 10:14 pm ] |
www.uniflow.com.au but they have agents everywhere, like Western Filters. Link to product- http://www.uniflow.com.au/contents/en-us/d141.html |
Author: | BALLISTIC [ Fri Aug 26, 2011 10:16 pm ] |
http://www.minis.com.au/minis/catalog/p ... cts_id=413 |
Author: | meeni [ Fri Aug 26, 2011 11:44 pm ] |
ive got a pipercross one on mine from minisport uk, as said above it just slips over the tubes and the difference with or without it is absolutely none |
