It is currently Fri Jul 18, 2025 10:38 pm
PostPosted: Sun Aug 28, 2011 1:23 am
hey guys, just trying to install a tahcho in my mini. 1275 engine with standard coil.
I need to know whether to calibrate it for 1 or 2 pulses?
PostPosted: Sun Aug 28, 2011 6:57 pm
probably just 1 - but if that doesn't work, try 2 :D
just a guess, but 2 would be for a wasted spark type ignition, which you don't have
PostPosted: Sun Aug 28, 2011 8:26 pm
You only get one chance with autometer, as it uses wire loops that need to be cut instead of switches. Or at least the last one I played with did.
Im pretty sure it will be 1 pulse on standard mini systems.
PostPosted: Sun Aug 28, 2011 9:48 pm
you can join the wire's back together, i think it is 1 pulse.
