It is currently Sat Jul 26, 2025 8:53 pm
 Post subject: Best Carb
PostPosted: Tue Aug 30, 2011 7:07 pm
just trying to figure out what carb would suit my engine best
it is a 1100s motor pretty well stock as far as I'm aware
so what would give me the best performance (without body mods)?
1969 mini k
PostPosted: Tue Aug 30, 2011 7:24 pm
1 1/2 SU would be a good starting point. No mods required
PostPosted: Tue Aug 30, 2011 7:25 pm
Either an HIF44 or an HS6 SU, on either an MG Metro or Minispares manifold.
PostPosted: Tue Aug 30, 2011 7:26 pm
Rover Cooper
They originally came out with 1 1/4 SU, single, so the engineers that designed the motor back in the late 60s must have known that would be sufficient for normal operation. :wink: :wink:
Twin 1 1/4 SU was always the first mod for a little more power, but the single is just fine. :wink: :wink: :wink:
PostPosted: Tue Aug 30, 2011 7:32 pm
Nope the 1100S (1275) all had an 1-1/2 stock, not 1-1/4...
PostPosted: Tue Aug 30, 2011 7:37 pm
I think the main reason for fitting twin carbys on the improved models was appearance.
Sure it will improve performance over a single 1¼" but the main thing was how it was perceived by the public.
A 1¾ will perform as good as two 1¼ but it will not look like it does.
PostPosted: Tue Aug 30, 2011 7:54 pm
yeah cool
i have a set of twin 1 1/2's that need to be rebuilt and was just wondering whether to stick with these or go down the hif44/hs6 route as what i have heard is that they are just as good
1969 mini k
PostPosted: Tue Aug 30, 2011 8:08 pm
Rebuilding twin SUs properly (if paying for it) costs serious $$$ now. And IMO twin 1.5s are overkill on an otherwise stock 1275.
PostPosted: Tue Aug 30, 2011 8:54 pm
I'm not an expert but my 1275 hoots along stock with a HS6. I gather it is a lot simpler than trying to tune twin carbs too.
Alec
PostPosted: Tue Aug 30, 2011 9:33 pm
by far the ultimate carburettor is a Weber.
The SU supposedly will wear and give you great dramas after 10-20,000km. Not worth the hassle.
Or something... :?
PostPosted: Tue Aug 30, 2011 9:45 pm
Or something... :?
Cheer up... :P
I don't hate SUs...
Here's what's going back on my 1412 when it's in the wife's van... HS6, ported Minispares manifold with 20mm spacer.
PostPosted: Tue Aug 30, 2011 9:58 pm
Milatsmadmini
Or something... :?
 Post subject: Which Carb?
PostPosted: Wed Aug 31, 2011 9:59 am
Hi All,
My two bob's...
although I love the twin's on my Landcrab I'm going to put a single on my Mini, fiddling with one set of twin's is enough :D
Ian
1961 Morris 850 (being restored)
1965 Austin 1800 (daily driver)
