It is currently Mon Aug 04, 2025 6:49 am
PostPosted: Thu Sep 01, 2011 4:08 pm
Is it as simple as different rotors and Callipers?!?!??!
Or is there more to it??
PostPosted: Thu Sep 01, 2011 4:16 pm
Drive flange is different as well.
I used 8.4" rotors turned down to 7.5" for my 4-pot callipers, not sure if you can do the same for Cooper S callipers though.
PostPosted: Thu Sep 01, 2011 5:49 pm
Depends on how you do it. I bought a kit from Mini Sport that had 7.9 vented rotors and four spot calipers and it was a straight replacement for the same bits on the 8.4 brakes. They also had a 7.5 version of the kit. Some wheels (usually the older ones) won't fit with the 7.9 rotors and even the ones that do require careful attention to where the balance weights go.
66 Deluxe, 07 Cooper
PostPosted: Fri Sep 02, 2011 2:30 pm
this is the basic kit. Any of the local suppliers can sell you the same parts
http://www.minisport.com/mini-spare-parts/info_MS2681.html
