It is currently Thu Aug 07, 2025 6:55 am
PostPosted: Tue Sep 06, 2011 6:36 pm
hi lads
are there any type of shims or anything like that to line these doors up?
my drivers side only wont shut, i need to slam the hell of out it to get it nearly shut & it jams, i found some shim looking things from them originally though but this is a new door.
PostPosted: Tue Sep 06, 2011 6:44 pm
Make them out of a coke can, you can cut them out with scissors and they wont go rusty. One can thickness on the lower hinge = about 5-6 mm at the back end. Hope this is helpful.
PostPosted: Tue Sep 06, 2011 6:55 pm
peter that is a freaking great idea :) you are the man will try this tomorrow.
PostPosted: Tue Sep 06, 2011 7:01 pm
You can make shims out of Coke cans, Milo tins and plastic drink bottles depending on the purpose. :lol:
PostPosted: Tue Sep 06, 2011 7:06 pm
Is the hinge old? They're crap and wear out like aussie ones, so check that too.
PostPosted: Tue Sep 06, 2011 7:18 pm
not worn.. it's not sitting right though to high.
i wonder if i can buy them hinge shims locally though? anyidea harley?
PostPosted: Tue Sep 06, 2011 7:34 pm
My idea is to man up, get some scissors and a coke can like the otehrs said and make some shims.
Hint: if you slot one side you don't need to remove the hinge bolts completely to slide the shim in and out when adjusting.
:lol:
PostPosted: Tue Sep 06, 2011 8:08 pm
hehe yeh i was thinking would be better having some steel shims.
ill make some up tomorrow.
