Hi guys, upon looking through my heap of parts, I found my new headlights (pictured below) that I bought ages ago, and totally forgot I had them to fit.
I have either lost the instructions or they didn't come with any, so for people who have fitted these type, could you please explain to me how they go together?
What sort of globes have people used in this type of headlight. I only want for this type, not others please. I've heard speculation that only certain bulbs can go into these, as they are Crystal eyes. I want bright lights at the front, so something decent. I will be installing relays on both high and low beam just for information.
Also to me it seems fitting that the lights around the edge should be hooked up onto a separate switch for show only. I don't exactly want mr plod pulling me up for this. Have any done this? Or do you run them colored and take the risk?
The last 2 questions I have is does the wiring plug on the end of the car fit the globes? I presume it would? Nothing needed to change there right? and does the blue insert just slip over the small light itself? It wont get hot and burn with the bulb on since its on the glass?
Any help, much appreciated guys. I'm not very good when it comes to electrics so want to make sure I've got everything sussed out, before I pull things apart.
