It is currently Fri Aug 08, 2025 12:30 am
 Post subject: Pot joint cage direction
PostPosted: Tue Sep 06, 2011 1:51 pm
Currently faffing about with my pot joints and did a search looking for the ball size. Came across this thread:
http://www.ausmini.com/forums/viewtopic ... +ball+cage
Isn't this cage around the wrong way? Might explain the difficulty he had fitting them?
PostPosted: Tue Sep 06, 2011 2:52 pm
Pretty sure it can only go in one way? From memory the outer race is not removable from the inner race, only the balls are? The toothed end is one side and a nylon plug on the other so it can only be placed uni directional to the drive shaft only and can't be 'flipped"?
Lillee - 1969 Morris Mini K
PostPosted: Tue Sep 06, 2011 3:02 pm
Yeah they're removable...how you think they get them together? :lol:
Have to take the inner off the shaft though, or slide the outer race off the other end of the drive shaft.
PostPosted: Tue Sep 06, 2011 3:03 pm
lol I'll take your word for it. All I ever do is re grease them and put a new boot on!
PostPosted: Tue Sep 06, 2011 6:24 pm
yeah the cage come off in-wards,,, in other words you "should`t be able to just slip the cage off the Pot end of the axle, it would need to slip up the shaft side
do you get what i mean?
whatever, i`m goin back to work :-)
PostPosted: Tue Sep 06, 2011 7:12 pm
Ya that's my point...so the one in the photo in the thread I linked to is backwards, and nobody trying to help noticed... :wink:
