lining up rover mini door. https://www.ausmini.com/forums/viewtopic.php?f=2&t=72868 |
Author: | NG [ Tue Sep 06, 2011 6:36 pm ] |
Post subject: | lining up rover mini door. |
hi lads are there any type of shims or anything like that to line these doors up? my drivers side only wont shut, i need to slam the hell of out it to get it nearly shut & it jams, i found some shim looking things from them originally though but this is a new door. |
Author: | peterb [ Tue Sep 06, 2011 6:44 pm ] |
Make them out of a coke can, you can cut them out with scissors and they wont go rusty. One can thickness on the lower hinge = about 5-6 mm at the back end. Hope this is helpful. |
Author: | NG [ Tue Sep 06, 2011 6:55 pm ] |
peter that is a freaking great idea ![]() |
Author: | Morris 1100 [ Tue Sep 06, 2011 7:01 pm ] |
You can make shims out of Coke cans, Milo tins and plastic drink bottles depending on the purpose. ![]() |
Author: | Harley [ Tue Sep 06, 2011 7:06 pm ] |
Is the hinge old? They're crap and wear out like aussie ones, so check that too. |
Author: | NG [ Tue Sep 06, 2011 7:18 pm ] |
not worn.. it's not sitting right though to high. i wonder if i can buy them hinge shims locally though? anyidea harley? |
Author: | Harley [ Tue Sep 06, 2011 7:34 pm ] |
My idea is to man up, get some scissors and a coke can like the otehrs said and make some shims. Hint: if you slot one side you don't need to remove the hinge bolts completely to slide the shim in and out when adjusting. ![]() |
Author: | NG [ Tue Sep 06, 2011 8:08 pm ] |
hehe yeh i was thinking would be better having some steel shims. ill make some up tomorrow. |
