It is currently Wed Jul 30, 2025 1:42 pm
 Post subject: Mini spit plans/pics
PostPosted: Fri Dec 09, 2011 6:28 pm
Evening All,
Starting to get all a bit serious about doing something with the old 61.
Does anyone out ther in Ausmini land have plans/dimensions/pics of Mini spits?
Going to need to mount mine up for some body work soon and so will need to build one.
Ian
1961 Morris 850 (being restored)
1965 Austin 1800 (daily driver)
PostPosted: Fri Dec 09, 2011 7:18 pm
Search - either here or with google gets easy results :)
Here's one design :
http://minimikebc.tripod.com/rotiss.html
Plenty around, seen the "two engine stands" type here a few times ;)
cheers,
PostPosted: Fri Dec 09, 2011 8:05 pm
Check out this link of mine;
http://s182.photobucket.com/albums/x314 ... otisserie/
What model mini is the spit for?
Later model clubmans will have different mounting options.
The difference in mounts will be seen in my photobucket pics :wink: .
PostPosted: Fri Dec 09, 2011 8:32 pm
Thanks Guys,
Lovin the pics Kennomini. Mines a 1961 so early.
What sort of height is yours?
Ian
PostPosted: Fri Dec 09, 2011 8:50 pm
Can't remember. If you mount the pole first then measure off that to the corners of the shell and then add a bit more and it should work out.
Users browsing this forum: fuzzy-hair-man and 98 guests
