Turning Circle https://www.ausmini.com/forums/viewtopic.php?f=2&t=72974 |
Author: | Wombat [ Sun Sep 11, 2011 10:24 pm ] |
Post subject: | Turning Circle |
What is the turning circle of a Mini ? Moke? If you have access that is 2.1 meters wide with a vertical drop on the right with a near right angle left turn ( concrete column on inside of corner and another column 2.1 meters opposite) can a Mini/Moke negociate it? |
Author: | pristic [ Mon Sep 12, 2011 11:58 am ] |
I say no... Mine has a terrible turning circle... thought it was just my setup... dont know the exact details on what the turning circle is though. Pete |
Author: | Maxi23 [ Mon Sep 12, 2011 12:09 pm ] |
My UK rack had a better turning circle than the aussie rack...but still pretty woeful. |
Author: | drmini in aust [ Mon Sep 12, 2011 12:11 pm ] |
I can't find it in my manuals, but the turning circle on Oz Minis is pretty poor, as they never got the UK's Mk2-on racks (which had another tooth or 2 on em). But at least we can fix OUR racks... ![]() |
Author: | sgc [ Mon Sep 12, 2011 12:14 pm ] |
C'mon, the turning circle is awesome, that's what the handbrake is for ![]() |
Author: | smac [ Mon Sep 12, 2011 2:33 pm ] |
Turning circle varies by model but pretty sure they were all over 8m, so a 90 degree turn is gonna be over 4m radius......no way it's getting around a 2.1m wide right angle, unless I've misunderstood the description. Oh and no way with the hand brake either... unless your mini is less than 2.1m long! ![]() |
Author: | CARTER_GT [ Mon Sep 12, 2011 3:30 pm ] |
Heres the sloution to make your turning circle smaller ![]() ![]() ![]() ![]() |
Author: | Irish Yobbo [ Mon Sep 12, 2011 6:18 pm ] |
If memory serves, a standard aussie mini has an 8.5m turning circle. I believe the rover racks are a little tighter. This really doesn't worry me - I'm used to driving a hilux (around 12.5m turning circle). I've found quite a few roundabouts that require a 3-point turn. |
Author: | Wombat [ Mon Sep 12, 2011 7:12 pm ] |
Oh well - just have to sick the nose around as far as I can and lift the back around ![]() |
Author: | drmini in aust [ Mon Sep 12, 2011 7:21 pm ] |
Maaaaaaaaaaaate, go buy some go-jacks or whatever them V8 supercars use.. ![]() |
Author: | Wombat [ Mon Sep 12, 2011 7:25 pm ] |
drmini in aust wrote: Maaaaaaaaaaaate, go buy some go-jacks or whatever them V8 supercars use..
![]() I've got some of the wheeled dollies - depends if I end up with a concrete floor or watered and vibrated road base ![]() |
Author: | 1071 S [ Mon Sep 12, 2011 7:27 pm ] |
I think you'll find the turning circle is something like 36feet - but I don't remember whether that is between curbs or walls.... But you right - a UK rack is a huge improvement - almost drove a mates car into a wall because I've become so used to the UK version. Why not stick some cardboard boxes on a flat piece of ground replicating your corner and see if you can make the turn... Cheers, Ian |
Author: | Speedwell Racer [ Mon Sep 12, 2011 10:31 pm ] |
My source says 8.7 metres. |
