It is currently Mon Aug 04, 2025 2:48 pm
PostPosted: Sun Sep 11, 2011 11:21 pm
Hi,
Last week my mini was running well, though as i got close to home it lost power and started to stall.
I had a play around with it today, and it seems to idle okay, though as i slowly increase the revs it starts to cough and splutter and backfire. I have checked the carbys and spreayed some cleaner down their throats though it didnt make much difference. I also removed the plugs and they were sooted up quite badly, I cleaned them up though it hasnt made much of a difference.
Any suggestions as to what the problem may be?
any help is appreciated!!
Thanks
Roc
PostPosted: Sun Sep 11, 2011 11:39 pm
I'd be saying timing. Have you marked where where the dizzy prior and now retarded. The other thing could be the Piston in the SU could be sticking
 Post subject: Mini Back firing
PostPosted: Sun Sep 11, 2011 11:42 pm
Hi Roc!
From what I can gather from your symptoms, I wouldn't mind betting it's your condenser in your dissy. Providing you have a standard mini one that is.
I had a similar problem with my mini once. A new condenser to replace the day old Bosch one cured it.
Regards, Lindsay
PostPosted: Mon Sep 12, 2011 8:06 am
+1 for okminik.
When mine backfired badly I found that there was a small crack in the distributor cap. Replacing the cap, condensor and rotor solved the problem. Just remember to set the correct gap for the points.
Users browsing this forum: drmini in aust and 108 guests
