i've just finished fitting Hyundai Getz seats into mine...
as i'm 6ft tall i figured the best spot for me to fit these seats was heaps lower than on the crossmember, so i've gone behind the crossmember and fabricated up brackets that bolt through the floor in 3 of the 4 mounts, the 4th bolts into the original seatbelt mount...
these seats look nice and are quite comfy, but i STRONGLY RECOMMEND NO ONE EVER FITS HYUNDAI GETZ SEATS! this was one of the worst projects i've ever had to do, they're borderline too wide, so rub on the rear pockets, i don't have any fore/rear travel they're solid bolted and the brackets were the biggest PITA to fabricate as none of the mounting spots on the seat are at the same height...
i'd go for an aftermarket set that has 4 flat mounting points on the same level or some use side mounts, again quite easy and would work well for behind the crossmember.
if you're still super keen for engineered seats, chat to the guys at Willshire Motor Trimmers (is willy still around here?)
i think something like this would be the easiest.
http://www.minispares-online.co.uk/?cat ... rod_id=714
http://www.minispares-online.co.uk/?cat ... rod_id=637
but for that amount of dollars i'd be getting some clubman high-backs fully re-done by a really good trimmer, you'll end up with some awesome seats.
