It is currently Sat Aug 16, 2025 1:50 pm
 Post subject: Advance Weight Spring
PostPosted: Mon Sep 19, 2011 1:05 pm
Had a peek inside my dizzy on the weekend, found one of the advance weights broken and jammed on the other spring.... the remainder was in the bottom of the dizzy....
Now Ken Nelson re-graphed this dizzy back in 2005 I think, and I in NO WAY suggest this was caused by his work..
Basically, are there different tension springs on the market....? How will I know which one to use?
PostPosted: Mon Sep 19, 2011 1:11 pm
Brad, spoke with Ken, best way is to send the dizzy back to him and he will have it sorted. The springs used would have been selected to suit the advance curve, so needs to go back to get the right spring/s.
Steve
PostPosted: Mon Sep 19, 2011 1:37 pm
Your bloody quick Steve!!!! Righteo! Ill get it shipped down to him. Thanks for finding that out for me!
PostPosted: Mon Sep 19, 2011 8:11 pm
That's OK Brad, no probs. And, I won't tell anyone that you broke down during the run yesterday :D I still reckon your car was sulking cause you took it out of its coon!
Steve
PostPosted: Mon Sep 19, 2011 11:03 pm
Ssssssshhhhhh!!!!
Nothing beats pushing a bit of British engineering off of a busy road!!! I was actually up to a good jogging speed by the end of it!!!
PostPosted: Tue Sep 20, 2011 5:19 am
Hi,
what dizzy is that ? Ducelier ?
nice bit of weld in the advance cam :P
Luis
PostPosted: Tue Sep 20, 2011 6:51 am
Hi Luis, it is 29D dizzy. Not sure if they were made outside Oz.
Steve
PostPosted: Tue Sep 20, 2011 7:14 am
Hi Steve,
thanks ;-) , never seen a Lucas dizzy like this, having the advance springs hooked on those up arms . I think Ducelliers work the same way... but not sure.
The nice thing is that you should be able to tweek the arms a bit to soften the springs action.
Luis
PostPosted: Tue Sep 20, 2011 7:37 am
Looking at my pile of dead dizzys, I think the 29D dizzy is the least durable one we ever got here- a 43D/45D is a much better unit. :wink:
PostPosted: Tue Sep 20, 2011 7:44 am
Hahahaha, thanks for the vote of confidence Kev!!!
Users browsing this forum: No registered users and 369 guests
