It is currently Sun Jul 20, 2025 9:40 am
PostPosted: Sat Sep 24, 2011 8:09 pm
Hi,
Just a brief rundown on the situation.
My mini was idling okay though when i gave it a bit of gas it lacked power and it would backfire from the carb & exhaust end.
Anyway, few people on this forum suggested that it may be as simple as a new condenser.
Now, I replaced the condenser and cleaned the points with fine grade sandpaper. Put everything back together and now there is no spark,.
I checked that the plastic washer was on right, checked the plugs, cap, rotor, rotor brush, internal wires inside the dissy and outside the dizzy for continuity with a multimeter etc etc. ALL OK.
I sprayed a bit of WD40 in the dissy and the spark came back, though as it dried i lost the spark again.
Any ideas or suggestions are much appreciated??
Thanks
Rocco
PostPosted: Sat Sep 24, 2011 8:14 pm
How is your timing?
Are you getting sufficient dwell angle?
You'll need a timing light and a dwell meter to get these right.
It certainly sounds point related.
PostPosted: Sat Sep 24, 2011 10:32 pm
Thanks, though the timing & dwell are okay, well were okay when the engine was running.
PostPosted: Sat Sep 24, 2011 10:38 pm
Check the condenser again, you may have got a faulty one!
Dalmeny
PostPosted: Sat Sep 24, 2011 10:39 pm
If WD40 fixed it but temporarily I'd say either the cap is dirty, or else has a crack in it..
Spray it with WD40 inside and out, wipe dry with tissues, spray inside again then refit... :wink:
PostPosted: Sun Sep 25, 2011 4:16 pm
Thanks All !
Got the spark back and the engine runs, though barely!!
Brings me back to my original problem, engine idles sort of okay, but when i give it a bit of gas it backfires from the exhaust and its barely driveable.
Anyway, there is a new condenser installed, so i guess i can rule that one out.
I have not mucked around with the timing or carbies and I know that they were fine prior to this issue arising, so any suggestions on what i should try next.
Thanks
Roc
PostPosted: Sun Sep 25, 2011 4:48 pm
Check the points gap- when they close up, weird things happen.
Last time it happened to me (moons ago) in my 1310S the engine would barely run under 4000 then went like a rocket to 7000.
I then binned the points, converted dizzy to electronic, and never looked back...:mrgreen:
If points gap is OK (.015"), try another coil- they can act strange when on the way out, as gafmo found recently.
PostPosted: Sun Sep 25, 2011 7:04 pm
We had a similar issue on our Mini K several years ago, it would run on 3 cylinders and you could hardly move it out of the garage, it would then clear and run perfect for a few minutes then die again and back onto what felt like 2 or 3 cylinders, it was undriveable, tried points, coil etc and finally noticed the wire in the dissy the one from the coil to the points was hanging by a couple of strands of wire, this was inside the dissy, at a quick look it appeared ok but when I moved it I noticed that it was almost broken off, the earth lead inside the dissy was not too good either. I replaced the complete lead from the coil to the points and it has run fine ever since. Might be something to have a look at, just a thought.
Users browsing this forum: No registered users and 61 guests
