Rear Wheel bearings https://www.ausmini.com/forums/viewtopic.php?f=2&t=73255 |
Author: | Fiji [ Mon Sep 26, 2011 7:13 pm ] |
Post subject: | Rear Wheel bearings |
This could b wrong but from first look one side has 2 Ball bearings separated by a spacer like my red 71-78 gregorys manual . The other has a bearing no spacer & a tapered roller bearing.? Normal ? Odd or am I seeing things. |
Author: | mini_mad_matt [ Mon Sep 26, 2011 8:09 pm ] |
Do you mean to say that 1 side of the car is the ball bearing type, and the other side of car has tapered roller without a spacer? Or do you mean the one side uses half tapered, half ball bearing? In which case that isn't really normal practice. |
Author: | Fiji [ Mon Sep 26, 2011 8:44 pm ] |
Post subject: | X |
Just what u said first. Didn't think they'd b different. Take it the tapered are better. |
Author: | VulcanBB18 [ Mon Sep 26, 2011 9:08 pm ] |
Original was the twin ball-races with spacer as per Gregorys An upgrade is to use twin taper roller bearings, with separate or integral spacer. Just seems in your case the PO has done one side but got tired/ran out of time/money/was tightarse and didn't do the other ![]() cheers, Jacob |
Author: | Fiji [ Mon Sep 26, 2011 9:44 pm ] |
Well let's see how much life is left in the twin ball racer type. Fun |
