Where to from here? Rear subframe
https://www.ausmini.com/forums/viewtopic.php?f=2&t=73275
Author:  123grosso [ Tue Sep 27, 2011 4:55 pm ]
Post subject:  Where to from here? Rear subframe
Hi guys, i have started stripping my rear subframe and i'm stuck on how to get this pin out, can i just bash it out with a hammer or is there a trick to it? I know it is a bit of a noob question but i just want to be sure so i dont kill any bits.
From this view do i bash it to the left or the right?
Cheers guys, thanks in advance
Author:  sitnlo62 [ Tue Sep 27, 2011 5:12 pm ]
There is no need to Bash anything...
You have to remove that outer bracket.
You have already removed two of the bolts.
There are two more bolts holding it to the subframe.
They are located above and below the shaft, inserted in the opposite direction to the two you have already removed.
They are probably hidden by grease and dirt.
Have a dig around with a screw driver and you will find them....
Good Luck,
Dave
Here is a pic of the bracket, should give you an idea where the bolts are....
Author:  123grosso [ Tue Sep 27, 2011 5:30 pm ]
Cheers mate
Author:  123grosso [ Tue Sep 27, 2011 5:58 pm ]
Now how do you take the handbrake cable out?
Author:  kirby [ Tue Sep 27, 2011 6:10 pm ]
I stumbled on the same thing, hidden under all that grease.
The handbrake cable is just held down by bent tabs, just bend them up a little and pull it out.
Author:  123grosso [ Tue Sep 27, 2011 6:16 pm ]
Are these the tabs?
Author:  michaelb [ Tue Sep 27, 2011 6:24 pm ]
Correct
And you can also spread the corner wedge pieces so you can pull the cable out of these as well
Author:  1071 S [ Wed Sep 28, 2011 6:43 pm ]
When you re-install the handbrake quadrants (top pic of handbrake cable) just remember that they are not symmetric (look carefully) and will easily install the wrong way 'round.
And if you do, the handbrake just won't work.....
Cheers, Ian
Author:  blue_deluxe [ Wed Sep 28, 2011 7:48 pm ]
Do you have a haynes manual? Handy thing to have and quicker than waiting for responses from here.
Author:  123grosso [ Wed Sep 28, 2011 8:47 pm ]
Yer i do, and the blue leyland book, i forgot about using them
Cheers, and thanks everyone for your replys
