25D Vs 45D Distributor https://www.ausmini.com/forums/viewtopic.php?f=2&t=73279 |
Author: | Rocco [ Tue Sep 27, 2011 7:25 pm ] |
Post subject: | 25D Vs 45D Distributor |
Hi, My A series 1275cc has a 25D distibutor with the vacuum blocked off due to the twin carbs. I think my dissy is playing up and i am thinking of replacing it, is it worth sourcing a non-vac distributor or is it okay to block off the vac on a new unit. P.S. Is there any difference between a 25D & 45D distributor? Thanks Roc |
Author: | drmini in aust [ Tue Sep 27, 2011 7:34 pm ] |
Non-vac 45Ds (actually called 43Ds) were used on Minis 1975-1978. Plenty about and they are a good robust dizzy. Even better if you toss the points and fit an electronic module (Pertronix etc) in them. ![]() I used one for years in my modified 1310S. |
Author: | 1071 S [ Tue Sep 27, 2011 8:11 pm ] |
Depending on the type of carb there's no reason to forego a vac advance because you have twins. And without it you're throwing away $$$. Cheers, Ian |
Author: | Kochie [ Tue Sep 27, 2011 8:20 pm ] |
Try the Nissan Pulsar dizzy, no points to worry about, I have had one for over two years and no problems Kochie ![]() |
Author: | drmini in aust [ Tue Sep 27, 2011 8:23 pm ] |
Kochie wrote: Try the Nissan Pulsar dizzy, no points to worry about, I have had one for over two years and no problems
Kochie ![]() I run a Pulsar in the 1360 and another in the 1412 stroker. Yes they work well, but even better if you get the advance curve modified. |
Author: | Fiji [ Tue Sep 27, 2011 8:27 pm ] |
do you have to take it somewhere special to get the advance curve modified |
Author: | drmini in aust [ Tue Sep 27, 2011 8:29 pm ] |
Graham Russell does them. Russell Engineering 113 North Rocks Rd North Rocks 2151 (02) 9630 2195 |
Author: | Fiji [ Tue Sep 27, 2011 9:18 pm ] |
cheers, i just bought one. but thats far a far away. i;ll let read speed have some fun with it. i'm sure he'll carve it up. ![]() |
Author: | drmini in aust [ Tue Sep 27, 2011 9:57 pm ] |
Fiji wrote: cheers, i just bought one. but thats far a far away. i;ll let read speed have some fun with it. i'm sure he'll carve it up.
![]() Reduce the centrifugal advance slot lengths to give about 10° max. See my how-to at top of mods forum. ![]() |
Author: | Fiji [ Tue Sep 27, 2011 10:39 pm ] |
will do thanks |
