Whirring noise from engaging cluth
https://www.ausmini.com/forums/viewtopic.php?f=2&t=73313
Author:  deg [ Thu Sep 29, 2011 9:23 pm ]
Post subject:  Whirring noise from engaging cluth
Push it in and a wurr it go. what now me dont know.
Engine does not lose any revs when pressed quickly and i have adjusted the clutch out a bit but still it persets any ideas and is it going to be fatal?
Author:  sgc [ Thu Sep 29, 2011 9:31 pm ]
If you put light pressure on the clutch pedal (enough to get the throwout bearing to engage) does it start to whirr/groan? Or does it only happen when you get it all the way in?
Author:  deg [ Thu Sep 29, 2011 9:59 pm ]
as soon as you touch it.
Author:  slacko [ Thu Sep 29, 2011 10:01 pm ]
sounds like the clutch thrust bearing in my opinion
Mark
Author:  sgc [ Thu Sep 29, 2011 10:05 pm ]
Mark
Yep, I'd agree. If it starts to groan with light pedal pressure, that's it.
Pretty easy fix, pop off the clutch cover (the "wok"), dismantle the clutch arm and throwout shaft, then you can drift the old bearing off and press fit a new one.
Only hard part is if the "hidden" clutch cover bolt has been fitted, it's a bastard to get out with the engine in the car.
Author:  deg [ Thu Sep 29, 2011 10:08 pm ]
IF i dont replace it soon can i do some serious damage or will she be ok for a bit?
Author:  sgc [ Thu Sep 29, 2011 10:12 pm ]
It'll go for a little while, but eventually the bearing will cry enough and destroy itself. Once its seized, you're then gouging the thrust plate on the clutch assembly which you don't want.
Just keep an ear out, once it starts to sound really bad, think about fixing it ;)
Author:  Lillee [ Fri Sep 30, 2011 1:00 pm ]
Replace with one of these and never have to worry about it ever again:
http://www.minisport.com.au/prod814.htm
