It is currently Mon Jul 28, 2025 12:50 pm
PostPosted: Thu Sep 29, 2011 5:34 am
Hi all.
I am going to stick the missing heater hoses back in the car and have a couple of questions..
Does the cylinder head hose go straight to the heater tap with the other hose from the heater returning water to the top of the radiator? (This makes sense to me)
How do the hoses get past the engine steady bracket? Can someone post a pic of this please.
Thanks.
Alec
PostPosted: Thu Sep 29, 2011 8:36 am
This pic will help you with the Radiator End: The LS came out with a metal tube,running from the bottom of the radiator to the top,where the heater hose connected to it ,then thru the firewall.
As for the cylinder head hose ,I'm running with an extra heater core to assist with the cooling system,so this pic won't help with that end.
PostPosted: Thu Sep 29, 2011 7:48 pm
Thanks. It is the pipe as it passes the steady bracket that perplexes me most t the moment.
Anyone else care to offer up a photo of a bracket for a 1275 with the hoses passing by?
Alec
