It is currently Fri Aug 22, 2025 12:11 am
 Post subject: Clutch issues
PostPosted: Tue Oct 04, 2011 7:00 pm
After cruising in the 850 for 20mins it became impossible to select a gear without pumping the pedal first. Today i checked the adjustments and all looks to be in order. Any ideas?
PostPosted: Tue Oct 04, 2011 7:42 pm
Tomboss Breweros
Low fluid?
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Oct 04, 2011 7:43 pm
I set the stop screw on the cover when hot, as expansion of the gearcase etc tends to increase pedal free play.
I like to have around 20mm or so freeplay at the pedal.
What gap is then at the stop screw, I have NFI. Some gap = OK.
PostPosted: Tue Oct 04, 2011 7:52 pm
Mine did the same thing when it wanted a new slave cylinder. :lol:
1977 Leyland Mini Van - Sold
PostPosted: Tue Oct 04, 2011 7:57 pm
Yes the symptoms do indicate this ^^^
If you buy a new slave I would use the seal spreader out of the old one.
Reason: new ones are wrong shape, don't spread seal, = seals don't last long...
Users browsing this forum: No registered users and 224 guests
