Clutch issues
https://www.ausmini.com/forums/viewtopic.php?f=2&t=73404
Author:  grey 64 [ Tue Oct 04, 2011 7:00 pm ]
Post subject:  Clutch issues
After cruising in the 850 for 20mins it became impossible to select a gear without pumping the pedal first. Today i checked the adjustments and all looks to be in order. Any ideas?
Author:  Tombo [ Tue Oct 04, 2011 7:42 pm ]
Low fluid?
Author:  drmini in aust [ Tue Oct 04, 2011 7:43 pm ]
I set the stop screw on the cover when hot, as expansion of the gearcase etc tends to increase pedal free play.
I like to have around 20mm or so freeplay at the pedal.
What gap is then at the stop screw, I have NFI. Some gap = OK.
Author:  Speedwell Racer [ Tue Oct 04, 2011 7:52 pm ]
Mine did the same thing when it wanted a new slave cylinder. :lol:
Author:  drmini in aust [ Tue Oct 04, 2011 7:57 pm ]
Yes the symptoms do indicate this ^^^
If you buy a new slave I would use the seal spreader out of the old one.
Reason: new ones are wrong shape, don't spread seal, = seals don't last long...
