Gauge Faces - Speed Conversion https://www.ausmini.com/forums/viewtopic.php?f=2&t=73411 |
Author: | seifer [ Wed Oct 05, 2011 9:02 am ] |
Post subject: | Gauge Faces - Speed Conversion |
Hey, quick question, I've bought a 110mph (180km/h) speedo for my clubman, the old/current gauges are however 160km/h. If i'm to get an accurate(ish) reading from the speedo should I replace the face on the new gauges with a 160km/h face or 180km/h? I'm just not sure how the ratios work on the gauges... I'm using these: http://www.heagren.com/gallileo/ Thanks |
Author: | Harley [ Wed Oct 05, 2011 9:58 am ] |
It all depends on what the newly bought speedo is out of. If its out of a mini, then it should work as is but if its from another car changing the face might not be enough. If its a new electronic one then it should be programmable. Mine goes up to 300 kph. ![]() |
Author: | seifer [ Wed Oct 05, 2011 10:27 am ] |
Yeah its just a standard mini but a 90's model from the uk with plastic covers. |
Author: | Harley [ Wed Oct 05, 2011 10:38 am ] |
In that case you should be okay, is the angle of needle movement the same from 0-100? Is the diff in your engine the original one with the correct drive, to your knowledge? |
Author: | seifer [ Wed Oct 05, 2011 12:07 pm ] |
To my knowledge its original. I just need to know I guess whether to use the 160 or 180km guage face, if the speedo cable spins at the same rate then itll be the 180km/h to suit the gauge, Correct? |
Author: | drmini in aust [ Wed Oct 05, 2011 2:53 pm ] |
It's not quite that simple.... ![]() UK Rover Minis varied the speedo drive gears down in the gearbox for various diff ratios. There are quite a few sets. But all Oz Minis had only the original 850's speedo drive gear ratio, and we changed speedos for the various diff ratios. |
