bluewhitecoopers1968 wrote:
I don't run a PCV valve, just 2 breather, one on the clutch housing and one on the back tappet cover to a catch can. Breathers are clear, that is I can blow into them, No oil in the catch can.
When you say you don't run a PCV, you run a catch can... Could you give a bit more info?
Do you have a vented oil filler cap? You've got the breather on the clutch cover - is it vented to atmosphere (through a filter?)?
Or is it feeding to the carby/inlet manifold..? You've got the rear breather to the catch can - is it vented to atmosphere or connected to the carby/inlet manifold..?
As the Doc says, cars can dump oil through the clutch cover breather after long left handers with decent revs. So that may explain the oil dump (it's the most likely exit - especially if it's not connected to anything).
But that doesn't explain your suction. Especially given you've not said the breathers are connected - in any way - to your inlet system. You've clearly said no PCV. If there's no PCV - especially if you're connecting to the inlet manifold direct, say, off your catch can - that would explain strong suction and rough idle.
If you can't hook up to your carby, but you want to plumb to your inlet manifold, you really, really do need a PCV.
My $14 breather is plumbed off my catch can.
