SPi rover mini - cat converter removal https://www.ausmini.com/forums/viewtopic.php?f=2&t=73618 |
Author: | Clutch-monkey [ Tue Oct 18, 2011 10:58 am ] |
Post subject: | SPi rover mini - cat converter removal |
being in the direct middle of the car it keeps scraping and getting bashed about. so just a quick question; if i remove it and just replace with a normal length of exhaust pipe do i have to fool the ecu or replace any sensors? |
Author: | Harley [ Tue Oct 18, 2011 12:24 pm ] |
No, the computer should cope. If your car has a catalyst overheat circuit / buzzer / light like some cars have then this is no longer necessary, removal won't affect the running. BTW: removing the cat from an unleaded engine is not legal, so you do so at your own risk. |
Author: | Maxi23 [ Tue Oct 18, 2011 1:15 pm ] |
Harley wrote: BTW: removing the cat from an unleaded engine is not legal, so you do so at your own risk.
Def. not legal. Getting caught results in a VERY hefty fine. ie, Thousands of dollars. |
Author: | Harley [ Tue Oct 18, 2011 1:18 pm ] |
Removing it because it scrapes on stuff is of little benefit, as everything else under there is the same height. Just wind your hilos up for a bit more ground clearance. ![]() |
Author: | EST-071 [ Tue Oct 18, 2011 4:46 pm ] |
Mine passed blue slip 4 years ago in NSW without one and has passed rego every time since. Cheers Pete. P.S If the car was built before 1986 it is not required to have one fitted, unleaded motor or not. |
Author: | kirby [ Tue Oct 18, 2011 5:18 pm ] |
EST-071 wrote: Mine passed blue slip 4 years ago in NSW without one and has passed rego every time since.
Cheers Pete. P.S If the car was built before 1986 it is not required to have one fitted, unleaded motor or not. Brave saying that on a public forum. |
Author: | Maxi23 [ Wed Oct 19, 2011 7:50 am ] |
But being an import Rover wouldn't it need to have a CAT to receive its original blueslip / engineers cert. ? |
Author: | Harley [ Wed Oct 19, 2011 8:09 am ] |
I think its all cars post '86 are supposed ti be unleaded/ have a cat on them. |
Author: | Clutch-monkey [ Wed Oct 19, 2011 8:26 am ] |
cheers! it is the ONLY bit of the car that scrapes as it is directly in the middle and hangs down to a mere 50mm off the tarmac - less than half the legal ride height requirement? so in that respect i'm between a rock and a hard place it seems! if i wanted to keep it i'd try and shift it to between the front or rear wheels but i'm on a budget at the moment so a simple pipe will do. |
Author: | Harley [ Wed Oct 19, 2011 8:33 am ] |
If its only 50mm off the ground then you need to checkbyour exhaust mounts, and your car is too low. The cat is the lowest thing under my car, and i set it at 100mm by adjusting the ride height. |
Author: | Clutch-monkey [ Wed Oct 19, 2011 8:55 am ] |
i went and had a look, looks like the front (stock) suspension is resting on the bumpstops, so yes might have to do some work there first ![]() |
Author: | EST-071 [ Wed Oct 19, 2011 3:33 pm ] |
Harley wrote: I think its all cars post '86 are supposed ti be unleaded/ have a cat on them.
Cats are only fitted to lower the emissions of unleaded fuel, it is not law that a cat needs to be fitted. However in saying that car manufacturers fit them as it is the cheapest and easiest way for them to be under the levels required by law which are stated in ADR 37. Cheers Pete P.S Commercial vehicles up to a GVM of 2.7t did not need one until the rules were updated in 2002, they were governed by rule 36. |
Author: | Clutch-monkey [ Thu Oct 20, 2011 3:10 pm ] |
honestly cops look at the car and see an old mini and assume it's an old mini, it's not a big deal if i do have to remove it in the end. will likely move it further down the exhaust system, such a stupid place to have it where it is. |
Author: | Harley [ Thu Oct 20, 2011 3:16 pm ] |
They're put there because they only work a certain distance from the exhaust on the engine, though even if not functional, technically it is still there and that'll satisfy the law. |
Author: | Clutch-monkey [ Thu Oct 20, 2011 7:56 pm ] |
Harley wrote: They're put there because they only work a certain distance from the exhaust on the engine, though even if not functional, technically it is still there and that'll satisfy the law.
good enough for me, though they're more likely to pick me for being too low honestly ![]() |
