It is currently Sat Aug 02, 2025 7:52 pm
PostPosted: Wed Oct 19, 2011 10:17 pm
Hi guys, I have a small issue, the brakes seem a tad slow.. ie press the pedal takes a moment to kick in. and then they stay on for a moment.
New Master cylinder
New brake Booster
Running mini sport 4 pot calipers
new brake hoses....
Any ideas? the Brakes havent been used in 12 months so I am hoping it could be a bit sticky, and will free up with use. :roll:
PostPosted: Wed Oct 19, 2011 10:19 pm
Immediate thoughtsa for problems:
1. pistons sticking on the seals, remove and lubricate.
2. One way valve in air line to booster suspect.
3. Minisport caliper.
PostPosted: Thu Oct 20, 2011 12:07 am
lol. Yeah just going to run it for a bit, and see how it goes! it feels sticky.
so Lets see what happens!
PostPosted: Thu Oct 20, 2011 9:04 am
Check the rear brakes too, my rover used to have 'sticky' brakes sometimes when the handbrake was released.
PostPosted: Thu Oct 20, 2011 9:40 am
Booster may need an overhaul, sounds like the air valve may be sticking...
PostPosted: Thu Oct 20, 2011 12:43 pm
Hope not, Its only brand new! Just going to see how it comes out.. COuld be a bit sticky from new
PostPosted: Fri Oct 21, 2011 9:14 pm
I'm no expert but just a thought, are the hoses the correct diameter and length? Of they are too narrow this may cause a restriction to fluid flow. Check them against the old ones.
Users browsing this forum: winabbey and 83 guests
